Old 11-07-2019, 12:40 PM
Sugarnutz Sugarnutz is offline
Default XMon Hookup Question
I've been using an Avid Omni for stereo monitoring but now I have a D-Command w/Xmon and I want to setup a surround monitoring system. I've been searching the Omni guide and wondering if it's possible to use the 8 I/O on the Omni to set up a 7.1 path without the Omni's front panel monitor level control bing in the chain, just straight +4 to the Xmon letting it control the levels. No luck so far. I have an Apogee Rosetta 800/192 I could use to feed the Xmon, but rather use the Avid conversion in the Omni. Any suggestions welcome. Thanx in advance.
HD Native Thunderbolt
HD6 Accel in Magma PE6R4 Expansion Chassis
PT HD 10, 11, 12, Ultimate 2018, 2019
Cubase 9.5 Pro
Vienna Ensemble Pro 7
Icon D-Command
HD Omni
192 Analog I/O 8 in/8 out/Digtal I/O
192 Analog I/O 8 in/Digital I/O
Two 192 Digital I/O
Apogee Rosetta 800, AD16X & DA16X (All wth X-HD cards)
Antelope Zen Studio+ Thunderbolt
15" Mid-2015 MBP 2.2 GHz i7 16 Gb RAM
512 Gb Flash Drive - OS X 10.14.3
Gigabyte z390 Designare
I9 990K 4.7 GHz
64 Gb of DDR4 3200
Gigabyte RX580 8 Gb
MacOS 10.14.5 Mojave
GIGABYTE GA-Z97X-UD7 TH
Intel Core i7-4790K 4.4 GHz
32 GB of DDR3 1600
EVGA GTX 760 Video Card
OS X 10.13.6 High Sierra & Win 7 Pro 64 bit
Dynaudio BM5 Mk III
B&W 604 s2
800W 15" Ported Subs
McIntosh MC-7106 Bridged ~ B&W
Hafler P7000 "Diablo" ~ Subs
Old 11-09-2019, 01:55 PM
Default Re: XMon Hookup Question
Hmmm, thought for sure that someone would have weighed in by now. I know the OMNI can do the 7.1 output scheme, but you would need to read the manual to find out if that can bypass the volume knob. With that in mind, is there a compelling reason to bypass it? Would it not be acceptable to calibrate it one time and leave it at that setting?
Old 11-09-2019, 04:37 PM
BScout BScout is offline
You bypass the volume control by not setting up the outputs as “speaker outputs” and just have them set as line outs. If you don’t define them as speakers, they are available as line outs.
Pro Tools Ult 2019.6, HDX 3, MTRX/SPQ, HD OmniMac Pro 5,1 - 3.06 GHz 12 core - macOS 10.13.6RAM 64GB, SSD 4 x 2TB, GPU GTX 980 4GB
Old 11-13-2019, 03:51 PM
Thank you! I think this might be a winner, makes sense anyhow.
Cubase 9.5 Pro
Icon D-Command
HD Omni
Two 192 Digital I/O
I9 990K 4.7 GHz
64 Gb of DDR4 3200
Gigabyte RX580 8 Gb
32 GB of DDR3 1600
Dynaudio BM5 Mk III
B&W 604 s2
MTRX hookup question, Dante vs Digilink SomeOtherGuy Pro Tools HDX & HD Native Systems (Mac) 26 01-03-2019 12:29 PM
new be question: correct hookup 11R in Mesa express effects loop? dsearles Eleven Rack 1 02-13-2014 06:26 PM
HD Native with 2 blue interfaces hookup question Justin1524 Pro Tools HDX & HD Native Systems (Mac) 5 09-03-2013 10:49 AM
Digi 002 Hookup Question jwd65 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 6 07-29-2004 10:04 AM
Dumb Hardware Verb Hookup Question COCO Tips & Tricks 2 02-08-2001 08:19 AM
