How can I Connect 3 192 I/O's in HD|1?
I have ProTools 8.03 with one Acell Core card. Can I connect three 192 I/O's? The diagram in my owners manual shows the third 192 I/O going to a second acell card. I don't want or need a second card. I don't mix in ProTools. I only use ProTools to edit from 24 track analog. So all I need is to dump in and out to my 24 track tape machine. I sure don't want to be spending another 4 grand for a card. there has to be a way get 24 tracks in and out via analog without another card????
Re: How can I Connect 3 192 I/O's in HD|1?
As far as I know, you need to have a card to connect each HD interface.
What I'm doing is running 2 888/24's in the legacy port of my 192. It's working for me, and those 888/24's are on eBay these days for about $100. HTH
Have a great day..... Bill ---------------------- Mac Mini (2019) 3.2 Ghz - 6 Core i7 Mojave with 64 GB RAM PT Ultimate (2019.10) Motu 16a C/24 Control Surface |
Impossible to get 3 192 into one HD card
BUT you can get 24 in and out on just 2 192 ( blue faced ) Just remove the AD A& DA cards from the third 192 and install in the 2 192's that you hook up This will give you 16 AD & 8 DA on #1 192 And 8 AD & 16 DA ON THE #2 192 This = 24 in and 24 out analog
http://www.studio-techservices.com าำ [email protected]mMitch Berger Tech Services We service ALL Avid products no Problem HD192, 192, Omni, Control Surface, Pre, XMON, 192HD AD & DA / Accel Cards, Everything ALL NEW HD192 AD -DA modification. the difference is incredible... no need to ship the entire unit , fast turn around inquiry using link above Repairs of SSL-Neve- Consoles and Repair ALL Modern & Vintage Gear |
Hi, you cant run more than 2 interfaces from one card. but you can expand the 192's with another 8 input or output card so you can have 24 i/o. each interface can have either 8 extra analogue in or out, so one interface can expand 8 inputs and the other 8 outputs. Chris
Thanks guys...I'm glad I didn't buy a third 192...this is definitely a rich man's game...and I thought buying a Studer A-800 back in the 80's was expensive!
any help please how to connect | alkhashti | MIDI | 1 | 07-10-2012 02:50 PM |
FW 400 to 800 connect! | ktwalker76 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 05-13-2011 01:41 AM |
Best way to connect 002 Cpu and HD | oulablank | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 10 | 10-15-2008 12:50 AM |
HD3 - How does it all connect?? | Gallellao | Pro Tools TDM Systems (Mac) | 5 | 04-19-2008 02:23 AM |
How to connect a sub to 001 | Doug Paluch | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 5 | 02-01-2003 09:54 AM |
