9173 error still/trash can, 35%cpu or less?
deal! anyone still having this "fixed" issue?
mac trashcan 8 core 64G RAM OS mojave PT 2019.5 Audient ID 22 |
Re: 9173 error still/trash can, 35%cpu or less?
I feel your pain.. I wish the industry would move away from PT it has become a unstable dinosaur
Intel Intel Core i7-5930K 3.5 GHz Processor ASUS X99-PRO/USB 3.1 Motherboard,64 GB crucial DDR4 ram Thunderbolt EX 2 Windows 10 Pro ................................ 2013 MacBook Pro Retina i7 Quad-core, 16gb ram. Mac OSX 10.11.6 ........... Mac Pro (Late 2013) 2.7 GHz 12-Core Intel Xeon E5 Memory 128 GB 1866 MHZ DDR3 Graphics AMD FirePro D700 6144 MB PT Ultimate 2022.4.0 on Mac PT Ultimate 2020.12 on Windows Logic Pro X 10.6 Nuendo 12.0 ........... 1_Antelope Audio_Orion Synergy Core Studio |
Not much info here. Please spend some ink so that someone may be able to help you
I'm experiencing the 9173 some minutes after opening and running a session. But it happens only one time. I'm doing an intensive test for discovering which plugin would cause this, if any. After many test I discovered that Kontakt in the plugin folder (even if not running) is the most responsible. But I have to investigate further. Btw the 9173 doesn't show up with only avid plugins in the plugin folder. I ran many sessions for many minutes going back and forth between one session to another, by closing pt, restarting the mac, reloading the missing plugins (after removing third party plugins from the folder) with avid plugins for loading the cpu and the hdx chips and never seen the 9173
Avid HDX - Avid HD I/O 16x16 Analog - Pro Tools Ultimate 2023.6 - Nuendo 11 Mac Pro 5.1 2 esacore 2.66 64GB Ram - Mac OS 11.7.7 |
I get the same error and usually only once.... and usually with the first session play through. I have found for me its due to forgetting to turn the internet connection off. If I turn it off prior to launching PT I dont get the error.
Rob MBP 15 2018 macOS Big Sur 11.6.8 Touch Bar and ID 2.2GHz 6 core 8 gen Intel Core i7 processor (TBs to 4.1GHz) 32 Gb of 2400MHz DDR4, 1T SSD, Magic Mouse and Keyboard Pro Tools 2022.7 -23.# - HEAT applied, RME Fireface UCX II ........and a bowl of M&M's |
Thank you for doing all this testing. I have the same 9173 situation as you (happens just once usually in the first 10 minutes of opening), although sometimes it's 6101 instead of 9173. I also have Kontakt and will try taking it out of the plugin folder.
Are you referring to wifi or internet in general?
Internet...... I run WiFi on a private network isolated from the internet to run EuControl without any issues. I believe there is a conflict happening between PT in play/record mode (I mean physically playing and recording) and the background chatter your PC does with your internet provider.
What interface are you using?
For years I've been using an Apogee Symphony through a PCIe card. Never get errors. I bought an Apollo firewire quad and after 30% CPU usage sessions were barely workable. I know firewire is outdated but just putting it out there that it was an interface issue with me |
AAE error -9173 with Pro Tools 2018.12 on macOS 10.14 Mojave | ramonetl | Pro Tools 2018 | 17 | 04-19-2019 08:44 AM |
VCA Function That Raises Some And Lowers Others? | NateAlexander | Tips & Tricks | 11 | 02-06-2019 05:05 PM |
1st Mojave error | mspin | macOS | 14 | 11-21-2018 05:15 AM |
Avid to drop prices on products!? | M-ManLA | General Discussion | 17 | 08-31-2011 11:19 AM |
