Old 01-09-2017, 09:09 AM
musicmaker123 musicmaker123 is offline
Default Cannot Resize Melodyne Plugin Window (Pro Tools 12.7) [solved]
SOLVED
So I just started using the Melodyne Studio plugin free trial and it worked fine until I tried resizing the window.
The plugin window can only be resized by using a button in the bottom right corner. My problem is that when I resized the window, the bottom part of the plugin went outside the window border - so I can longer access the resize button or the horizontal scroll bar at the bottom (to move side to side and zoom).
Here's a screenshot for a more clear explanation:
I'm not sure if the problem is caused by Pro Tools or Melodyne software but I would like to resolve it without losing the Melodyne edits I have already made. The plugin works normally other than this issue.
Any ideas?
Thanks
Old 01-09-2017, 09:13 AM
YYR123's Avatar
YYR123 YYR123 is offline
Default Re: Cannot Resize Melodyne Plugin Window (Pro Tools 12.7)
Who know where the fault lies but....you can try a few things.
Try running a different screen resolution on your PC.
Then restart PT and see if the location is visible......
Try opening another plugin window and resizing it using the restore down/up button. That the button in between the close X and the minimize.
Look at the melodyne manual for a shortcut key press to maximise or minimize the plugin window.
Daniel
Old 01-09-2017, 09:39 AM
Messed around some more and found a fix!
If anyone has this issue, this is what I did:
1. Changed my screen resolution to the lowest possible resolution.
2. Opened Pro tools and created a new session with I/O settings changed from Last Used to Stereo mix.
3. I then created a new insert of Melodyne plugin and the plugin window border was now FIXED.
4. I then resized the plugin window to a smaller size using the bottom right corner (now visible).
5. I reset my resolution setting back to normal and saved the session.
6. I reloaded the old session that had was bugged and the plugin window was back to normal.
Old 05-11-2017, 10:34 PM
vctorsound vctorsound is offline
Default Re: Cannot Resize Melodyne Plugin Window (Pro Tools 12.7) [solved]
wow... nice work, an elegant solution to that problem... i'm gonna try that tomorrow, window drove me crazy all day today... thanks!
Old 05-26-2019, 11:11 AM
chrismeraz chrismeraz is offline
does this happen often? I've just started using the trial version today and I already have this problem. How often has this happened to you?
ATC SCM50ASL
Apollo x8
MacBook Pro M1 MAX
Pro Tools Studio
www.studioaix.fr
Old 05-26-2019, 11:35 AM
Southsidemusic's Avatar
Doesn’t happen here and this is a 2+ yo thread so several versions has come and gone since.
Best Regards
Christopher
#thestruggleisreal
South Side Music Group
WEBHOME
Old 05-26-2019, 11:47 AM
It's happened to me again 15 minutes later.
This issue is not solved permanently with Musicmaker's instructions.
ATC SCM50ASL
Apollo x8
MacBook Pro M1 MAX
Pro Tools Studio
www.studioaix.fr
Resize a plugin window? Aboy Pro Tools 10 1 06-14-2013 11:44 PM
How can I resize the plugin window is it possible phatbeatstudio macOS 7 03-13-2012 11:46 AM
resize window size eivind 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 02-11-2006 09:01 AM
Window Resize/Position Glidej 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 01-15-2006 09:56 AM
Resize Quicktime Window shadowbox Pro Tools TDM Systems (Mac) 15 12-11-2003 12:27 PM
