  #21
Old 11-11-2016, 06:17 AM
Default Re: Upgrade Pro tools 10 and Lion
Originally Posted by ctrack View Post
Great, this gives me something to think about...
Until I change my gear or upgrade, any tips on how to optimize the performance of the Imac/PT10 right now?
I already have installed max ram (16GB), repaired disk/disk permissions and all software are the latest versions. I'm not running other programs when using ProTools, and there are lots of HD-space left.
What exact iMac do you have? You may be able to install 32 gig ram. Otherwise in addition to what you've done use a separate drive for pT to record to and a separate drive for samples.
Jack
QAPLA!
  #22
Old 11-11-2016, 06:51 AM
ctrack ctrack is offline
Unfortunately 4 x 4 GB ram is max, and extra ram hasn't helped a lot.
Any suggestions on what drives to get for an imac 2.7GHz, mid 2011?
  #23
Old 11-11-2016, 06:53 AM
Thanks for the links, Ben
  #24
Old 11-11-2016, 07:07 AM
Drew Mazurek's Avatar
RAM and SSDs are often overrated for performance improvements.
I'm not a computer expert but if this guy is, then this video will help you understand what's important.
https://www.youtube.com/watch?v=GUsLLEkswzE
www.drewmazurek.com
  #25
Old 11-11-2016, 07:29 AM
JFreak's Avatar
JFreak JFreak is offline
True. As far as memory is concerned, you need a reason for having more memory, like for example buying PT10HD or later and wanting to use Disc Cache for 2 hour recording session. In that case it surely helps a lot. SSD on the other hand just launches software faster, so if you launch more software than you need it is actually counter-productive
Janne
  #26
Old 11-11-2016, 09:04 AM
reichman's Avatar
reichman reichman is offline
Is it correct to say, that buying PT12 and the appropriate OSX on my relatively old imac with i5, wouldn't necessarily make it faster or able to run with more plugins?
Wrong. PT12 will run WAY more plug-ins on the same Mac than PT10. Difference is night and day. I've done extensive testing of this.
Nathaniel Reichman
Supervising Producer – Re-recording Mixer
Dubway Studios
  #27
Old 11-11-2016, 10:17 AM
That's wrong; what you're quoting is what Apples says you can put in. The real amount IS 32 gig whether you have the 21.5 inch or 27 inch. Check OWC.
Like I said for the drives you have to be careful that the drive has the specific temp monitoring connections. Again check the OWC site - they should be able to steer you right.
Jack
QAPLA!
  #28
Old 11-15-2016, 03:29 AM
Hey thanks again all!
Great tips and info - looking forward to having my music running properly again.
Ctrack
Lion to mountain lion upgrade file needed, anyone? Audioartist macOS 0 09-26-2015 08:46 AM
Impossible to start Pro Tools on MacPro after downgrade Mountain Lion back to LION DESVED Pro Tools HDX & HD Native Systems (Mac) 2 05-21-2013 03:18 PM
Pro Tools Academic 7.3.1 - Upgrade to Lion rekington Pro Tools M-Powered (Mac) 0 12-12-2012 08:57 PM
Upgrade Pro Tools 10 OS X Lion MrSteno macOS 2 11-19-2011 02:38 PM
Pro Tools Mbox Lion Upgrade Question! simonjefferis macOS 2 10-19-2011 02:49 PM
