Old 10-22-2020, 10:42 PM
Picture Start Picture Start is offline
Default S1 Automation Modes on Soft Keys
I have had luck programming all the soft keys to any parameter I want, with the exception of the automation modes. I just want to be able to have a soft key that makes the selected track go into Touch/Latch mode. Is there a second button or modifier that needs pressing or something? This is really unintuitive, as it appears from the manual and the Eucon guide you should be able to program any parameter to a soft key and just go.
Old 10-23-2020, 01:46 PM
Default Re: S1 Automation Modes on Soft Keys
Hmm, ok so I discovered that if I assign User 1's soft key to "Touch/Latch", then hold that button down while clicking the channel's Sel button, it works. That makes sense from the standpoint of how you'd do it on a desk. I think the documentation needs to specify that for this subset of EUCON rules, this is a modifier key, not a command. I suppose the upside is you can apply your automation change to multiple tracks if desired, so I assume it doesn't just look at your selected track and change it.
Is there a way to make a multi-step Eucon SK patch where pressing one key does the work of these two keys, using the currently-selected tracks?
20.1.0 automation mode soft keys still not working bartosz idzi Artist Series 6 02-19-2020 10:37 AM
Using F keys - cycle through modes doesn't work sloanlogic Pro Tools 2018 4 04-04-2018 09:22 PM
S6 Master/Automation Soft Keys Not Working MoreMe Avid S4/S6 3 03-16-2018 11:08 AM
Automation modes won't change on MC Control v2 on the touch panel and soft buttons filmsound_no Artist Series 6 11-24-2011 12:55 AM
Lost Automation Modes Soft Keys in 2.5.6 mystic merlin Artist Series 19 05-23-2011 02:21 PM
