Old 02-06-2002, 08:29 PM
Jason from MaggieJack Jason from MaggieJack is offline
Default Snare Drum Resonance
When recording a drum set the snares vibrate with tom hits and sometimes kick drum hits too. I've tried tightening snares and some tape wich worked pretty well but I would like to know if any of you have other solutions. It would be great to take care of the snare vibrations pre recording instead of later.
Thanks,
Jason
Old 02-06-2002, 09:44 PM
bassmac bassmac is offline
Default Re: Snare Drum Resonance
Try laying a thick blanket across the the top of the kick drum.
Old 02-07-2002, 02:59 AM
gerax gerax is offline
Hi
I think there's no definitive solution, I usually go with tape whenever I have this kind of trouble, also try to tune the snare head and bottom slightly different, to see if they react differently to the vibration inducted (by the way, did you find out what other drum in the kit - or other instrument - triggers that vibration?).
Hope this helps
L.G. [img]images/icons/smile.gif[/img]
Old 02-08-2002, 07:28 AM
Thanks guys I'll try those suggestions.
There is the kick and two toms and they all seem to affect the snares, the high tom the most, then the kick.
Basically though would you guys agree this is something to take care of before hitting the convertors?
Jason
Old 02-08-2002, 01:11 PM
s.d. finley s.d. finley is offline
You could also try gating the snare after the fact, or you could to automate the volume on the snare too.
sdf
sdf
sugarhillstudios.com
Old 02-08-2002, 06:23 PM
I would try to get rid of any unwanted noise before you record a single note: once recorded it will be there, and you'll have to work twice as hard to take care of it, so why not put a little more energy before; if you minimize (or eliminate ) it a little gating and filtering could be the right cure when mixing; don't gate when you record it, or you'll risk to loose some hits.
Old 02-08-2002, 07:18 PM
where02190 where02190 is offline
simpathetic vibrations are part of a drum kits sound, and although you don't want bad drum sounds, you also don't want a drum that goes thud and dies. Learn to tune properly, tighten all lugs, hardware (inside and out) etc to get rid of any rattles, keep pedals well oiled, and of course there is no substitute for a good player either.
Snares have a major varience in sounds, and some have more sympathetic vibrations than others, and a selections of mroe than one snare is always good but not always in the budget for smaller studios.
Old 02-09-2002, 01:42 PM
Right on thanks everyone. Gates are a hard thing to dial in without losing the attack of the drums, so I definetly will work on it before recording.
Jason
Old 02-10-2002, 09:34 AM
Bob Olhsson's Avatar
Bob Olhsson Bob Olhsson is offline
I've seen just replacing the snares work wonders.
Bob's room 615 562-4346
Georgetown Masters 615 254-3233
Interview
Artists are the gatekeepers of truth! - Paul Robeson
Old 02-11-2002, 12:53 AM
Right on Bob I had thought about that too, now I'll try it for sure.
Thanks
Jason
Help with snare drum lost in mix Raoul23 Tips & Tricks 6 05-05-2011 09:51 AM
how to use a preamp on a snare drum rogee 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 01-16-2008 09:59 AM
The Snare Drum Eless 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 02-28-2006 04:46 PM
8^( ..Snare Drum Help Please ..8^( PRS4LIFE 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 6 03-27-2004 11:47 AM
snare drum mic? s.d. finley 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 23 07-28-2000 12:11 AM
