Re: pro control db25 cables for monitor section
How do you guys go about connecting your monitors to the pro controls monitor section with db25 cables? My monitors are about 4 to 5 feet apart which seems farther than the cables will spread because the db25 cables are wrapped till the end of the cable where it fans out to the 8 trs or xlr cables.
Do you use a short db25 to female trs or xlr and connect trs or xlr cables to those that go to the monitors and the headphone amp? |
Yeah I always use, adaptors off of the main cable, whatever they may be to reach.
I build my own cables just so I have exactly what I need and so they don’t cost a fortune. I never used the PC as a monitor unit, I always had 3rd party units for monitoring....just because they were more robust, offered more io and were lots cleaner. The PC was great as a control surface but it didn’t have a great monitoring control sound...especially this far into the game.
But using a short db25 and extend it with extension cables will work fine too. Make sure you use xlr and not trs, because xlr connectors do make contact on a large surface (it's a large pin within a large buss) while trs connectors do make contact on a very small surface (point-to-point).
Marc Schellekens Delta Music Belgium - Dolby Atmos Music Studio https://www.deltamusic.be Mac Pro 2019 - 3.2GHz 16-core - 96GB RAM - macOS 14.4.1 - PT HDX3 - Pro Tools Ultimate 2024.3.1 - Avid HD I/O 16x16 (x2) - Avid HD I/O 16x16 Digital - Digidesign 192 I/O - Digidesign 192D I/O (x3) - Avid SYNC HD - Apogee Big Ben - Apogee Rosetta 200 - Avid S3 - Slate RAVEN MTi2 (x2) - iConnectivity mioXL (x4) - Genelec ‘The Ones’ 9.1.6 Dolby Atmos Music monitoring (AES/EBU) with 8341A (x5) + 8331A (x10) + 7360A (x2) + 9301B - Almost all available AAX-DSP plug-ins |
PLEASE HELP!!! Control 24 Monitor section SURGING!!! | Table Syrup Records | ICON & C|24 | 2 | 01-07-2008 07:56 AM |
Upgraded monitor section on a Pro Control? | joesgarage | ProControl, Control|24, Command|8 | 2 | 10-16-2006 05:31 PM |
control 24 monitor section woes | insolace | ICON & C|24 | 4 | 05-18-2005 09:30 AM |
Monitor control room section | Tomio Broman | ProControl, Control|24, Command|8 | 1 | 05-19-2003 10:57 AM |
Pro Control Monitor Section-Please Read | Techsupt2 | General | 0 | 11-03-1999 03:38 PM |
