Fast Track Ultra & M-Powered - Do I need to upgrade my computer?
Any insight would be great. I'm completely set up and having what seems to be horrible latency issues. I really only need to be able to record simultaneously on 4 tracks with no plug-ins. Here is what I'm using:
Computer Model : Dell Computer Corporation Dimension XPS Workgroup : MSHOME Host Name : XPS User : Beau Richards Processor Model : Intel(R) Pentium(R) 4 CPU 2.80GHz Speed : 2.8GHz Cores per Processor : 1 Unit(s) Threads per Core : 2 Unit(s) Integrated Data Cache : 2x 8kB, Synchronous, Write-Thru, 4-way, 64 byte line size, 2 lines per sector L2 On-board Cache : 2x 512kB, ECC, Synchronous, ATC, 8-way, 64 byte line size, 2 lines per sector Computer Mainboard : Dell 0F2905 BIOS : Dell Computer Corporation A02 07/21/2003 Bus(es) : X-Bus AGP PCI IMB USB FireWire/1394 i2c/SMBus Multi-Processor (MP) Support : No Multi-Processor Advanced PIC (APIC) : Yes Total Memory : 1GB DIMM DDR Chipset Model : Dell 82875P,E7210 Memory Controller Hub Front Side Bus Speed : 4x 200MHz (800MHz) Total Memory : 1GB DIMM DDR Memory Bus Speed : 2x 200MHz (400MHz Memory Module(s) Memory Module : Nanya NT512D64S8HB1G-5T 512MB DDR PC3200U DDR-200 (3-3-3-8 2-11-0-0) Memory Module : Nanya NT512D64S8HB1G-5T 512MB DDR PC3200U DDR-200 (3-3-3-8 2-11-0-0) Video System Video Adapter : RADEON 9800 SERIES (PS2.0, VS2.0 378MHz, 128MB 337MHz, AGP 3.00) Storage Devices WDC WD1200JB-75CRA0 (120GB, ATA100, 3.5", 7200rpm, 8MB Cache) : 112GB (C MAXTOR 6L040J2 (40GB, ATA133, 3.5", 7200rpm, 2MB Cache) : 37GB (E HL-DT-ST CD-RW/DVD-ROM GCC-4480B (ATA33, DVD-R, CD-RW, 2MB Cache) : 3GB (D TDK DVDRW0404N (ATA33, DVD+-RW, CD-RW, 2MB Cache) : N/A (G Peripherals LPC Hub Controller 1 : Intel 82801EB/ER (ICH5/ICH5R) LPC Interface Bridge LPC Legacy Controller 1 : SMSC LPC47M172 Audio Device : Creative Labs SB0243 Audigy 2 (OEM'd For Dell??) Serial Port(s) : 2 Parallel Port(s) : 1 Disk Controller : Dell 82801EB/ER (ICH5/ICH5R) EIDE Controller Disk Controller : Dell 82801EB (ICH5) SATA Controller USB Controller 1 : Dell 82801EB/ER (ICH5/ICH5R) USB UHCI Controller #1 USB Controller 2 : Dell 82801EB/ER (ICH5/ICH5R) USB UHCI Controller #2 USB Controller 3 : Dell 82801EB/ER (ICH5/ICH5R) USB UHCI Controller #3 USB Controller 4 : Dell 82801EB/ER (ICH5/ICH5R) USB UHCI Controller #4 USB Controller 5 : Dell 82801EB/ER (ICH5/ICH5R) USB 2.0 EHCI Controller FireWire/1394 Controller 1 : Creative Labs Audigy 2 Firewire Controller SMBus/i2c Controller 1 : Intel 801xx/63xx SMBus |
Re: Fast Track Ultra & M-Powered - Do I need to upgrade my computer?
You should monitor through the M-Audio mixer and mute the tracks you are recording to in Pro Tools. There will be no (or near-zero) latency there on the M-Audio mixer. This is the workaround for the M-Audio setup with Pro Tools. It will record in sync with the rest of your session.
I create 'Tracking Tracks' that are muted and set up with the correct i/o, then move things down to other tracks when we get a good take. If you need to punch a section, edit out the part on the keeper tracks and record over on your Tracking Track then edit together. Unfortunately, if you want to punch like a normal tape machine, you need PT HD.
Dell Studio 1555 Laptop, Intel Core Duo T6600 2.2GHz, 4GB RAM Windows 7 64-bit Pro Tools M-Powered 8.0.4cs2 M-Audio Firewire 410 via Digi-Qualified SIIG FireWire 2-Port ExpressCard {NN-EC2012-S1} Glyph 050Q 500GB via eSATA |
You should monitor through the M-Audio mixer and mute the tracks you are recording to in Pro Tools. There will be no (or near-zero) latency there on the M-Audio mixer. This is the workaround for the M-Audio setup with Pro Tools. It will record in sync with the rest of your session. This is the same as working with the USB Mbox interfaces.
I create 'Tracking Tracks' that are muted and set up with the correct i/o, then move things down to other tracks when we get a good take. If you need to punch a section, edit out the part on the keeper tracks and record over on your Tracking Track then edit together. Good method. Unfortunately, if you want to punch like a normal tape machine, you need PT HD. This is not accurate(but you DO need a faster computer). Any modern quad core system should be capable of recording several tracks at the 128 buffer(or 64 if its available). In any case, your old P4 with 1gig of RAM is WAAAAY under-powered for version 8. You may also be losing performance due to the small cache on your drives(especially if you are recording to the Maxstor).
Yes your computer is underpowered for audio production. If you want to get the most out of the Pro Tools software I suggest a quad-core processor, 4 gig of ram, at least a 256 MB pcie video card, and at least 2 SATA II hard drives with NCQ or any variant of it. If you looking to buy a workstation from a Systems Integrator I suggest the Dell Precision Workstations. If you will be building it yourself then you have much more flexibility in your component selection.
PC Asus P6T WS Pro | Xeon W3520 at 3.6ghz | 6 gigs 1600mhz DDR3 | Nvidia FX580 | 2x Intel X25-M 80G SSD (Win OS + Mac OS) | 2x WD 160 gig RE2 Enterprise SATA HD | 2x Seagate 7200.12 1Tb SATA HD | Dell 2408WFP 1920x1200 | Pro Tools HD 8.0.3cs1 (PCI-X) | Mac OS X Snow Leopard 10.6.2 | Windows 7 Professional 64bit Mac Dual 1.2 G4 | Mac OS Tiger | Pro Tools M-Powered 7.4 |
I was referring to zero-latency within a Pro Tools session - which you can only obtain with HD (or just use a Studer A80 24 Track). 128 samples is too much for recording vocals, at least for me and my clients.
I tried muting the record-enabled tracks and monitoring through the Fast Track Ultra and I'm still experiencing the same result:
1. Random and loud pops/clipping throughout recording 2. Extreme latency/delay after hitting "Record" 3. Recording duration cannot exceed about 10 seconds (even when recording a single track) 4. After those 10 seconds, "Low on CPU Power" warning and recording is ended. Does anyone have any idea what the problem is? |
Fast Track Ultra 8R restarting computer | Al1G | FireWire & USB Audio Interfaces (Win) | 9 | 12-24-2013 06:10 AM |
M-Powered Fast Track Ultra 8r problems | bensarno | Pro Tools M-Powered (Win) | 2 | 05-02-2011 12:57 AM |
Fast Track Ultra 8R and M-Powered 8 | foxg | Pro Tools M-Powered (Win) | 0 | 03-02-2011 02:23 PM |
laptop for m-powered 8 and fast track ultra | OsvaldoDavis | Pro Tools M-Powered (Win) | 2 | 12-07-2009 04:09 AM |
M-Powered 7.4 and M-Audio Fast Track Ultra | taveren93hgk | Pro Tools M-Powered (Win) | 3 | 04-29-2009 10:21 AM |
