Pads
I recorded a band the other day and one of the most frustrating things is that there are no pad switches on the 003 rack pres, and the snare was constantly clipping. I had to run it through my o1v which i had connected through adat. it was a quick work around but i didn't think the pre's in the o1v sounded as clean as the 003 rack...
does anyone know of a way to reduce the level of the pre because it was peaking even when it was wound all the way down. is it possible to add a pad switch to it in any way? thanks |
Re: Pads
QS G4 Powerlogix Dual 1.6Ghz 1.5GB RAM Digi001 10.3.9 PT 6.4 Powerbook 1.5GHz 1.25GB RAM |
Re: Pads
will there be any loss in signal quality if i was to use this at all? i'm not entirely sure how or whether a pad affects the quality of the pre or the mic
Re: Pads
You could always go to Radio Shack and buy an XLR to TRS ( 1/4 ) adapter, or a regular TRS Mic cable and send a Line Level from the snare into the Line Inputs on the 003 ,or a regular TRS Mic cable You'll have a pad on those If you need it.
Yes the Mic pre's will sound better but it won't hurt to try
Stay true to the sound,Less is best |
Re: Pads
Much better than running a mic to a line input!
002R PT7.3.1 MacBook Pro 2.33 OS 10.4.8 |
Re: Pads
sweet, thanks for that...i was hoping there was something better than running it into a line...not something i'd really want to do. thanks again
I pads and V-pro | sw rec | Pro Tools 10 | 12 | 12-28-2012 08:21 AM |
Something with pads | Stig Eliassen | Virtual Instruments | 13 | 02-14-2011 02:09 AM |
Transfuser pads mapped to axiom pro pads | th3actor | Virtual Instruments | 0 | 09-02-2010 04:22 PM |
C24 - no mic pads? | rtcstudio | Pro Tools TDM Systems (Mac) | 13 | 01-22-2010 03:41 PM |
Stationary Pads | Sarah Faust | Post - Surround - Video | 2 | 01-31-2002 06:25 AM |
