digidesigns AS plugins
do the digidesign or bomb factory audiosuite plugins introduce latency?
Re: digidesigns AS plugins
RTAS plugs should not introduce latency... Audiosuite plugs process off line, so there would be no latency with those at all.
White Macbook OSX 10.5.5 2.2Ghz Core 2 duo 4Gb RAM PTMP 7.4.2 M-Audio Profire 2626 and Focusrite 26 I/O via lightpipe. Focusrite Platinum Voicemaster Pro KRK RP8's 1Tb Dual drive array. |
Some RTAS plug-ins will introduce latency. Audiosuite plugs don't introduce any latency.
thanks fellas, can digisupport confirm this?
I can confirm it for you - there are several RTAS plug-ins that introduce latency. Like mradlauer1 said, AudioSuite doesn't because it's a rendered process. The latency with Audiosuite is the processing.
You can check the latency of RTAS plug-ins by cmnd-clicking the volume scribble on the channelstrip that holds the plug-in. |
Digidesigns Hardware issues,post them here... | gdx | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 05-06-2008 11:40 AM |
digidesigns hardware is in use problem! | jakeelee | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 11 | 11-26-2004 12:01 AM |
Digidesigns support for Windows | Holadrio | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 7 | 05-17-2004 12:15 AM |
My IRQ says I have 2 Digidesigns in 10 and 11. | TriAxis | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 05-09-2001 11:19 AM |
What are Digidesigns plans for Surround Plug-Ins? | Ah D O | General Discussion | 1 | 04-15-1999 01:39 PM |
