Looking to purchase New Mac for pro tools, help!
Hey All,
I tried looking for this topic but couldn't find it anywhere. so Currently I'm running a Late 2011 macbook pro. 500GB storage and 4GB of memory. Most of my sessions only contain about 20 tracks max! but obviously due to the lack of memory, it's giving me problems and it's time for a new mac anyway. I am on a budget, so I'm definitely trying to save money wherever I can. Unless, I have no choice. but that's why I'm here. for you to advise me. My question is ... I see that 16gb memory is now the least required? since when? I remember 8gb was. Also, what about storage? The mac with the least storage has 128 GB of storage. Would that work if I have an external LaCie drive (1TB) ? or should I go with 256gb? In conclusion .. Should I go with 8gb of ram or 16gb or ram? and 128gb of storage since I have a LaCie external drive of 1TB, or should I just go with 256gb? thanks again !!! |
Re: Looking to purchase New Mac for pro tools, help!
What do you mean by 'storage'? Are you talking about the system drive? If so you can always change out the one in your current MBP (you don't give us any ideas of what's in that machine and that would be helpful). Again OWC to the rescue with an SSD; cost depends on size you want. What Mac are you looking at? Again that kind of info would be helpful as would bee budget. Ram is soldered in on current MBP's; not sure if system drives ar user changeable or not. What I'm getting at is you may not need a new machine; the options I list would help you get a few more years out of your current one. A big thing to keep in mind is that all new Macs come with High Sierra and that has not been qualified for PT12. Don't expect that for a while if Avid history is any indication. |
Hey, strongly appreciate your response man.
By storage I mean hard drive space, but I have enough of that on my current, it just seems to be very slow lately. I believe the most ram you can add to my current mbp is 8gb The mbp I was looking at has : Hardware 2.3GHz dual-core 7th-generation Intel Core i5 processor, Turbo Boost up to 3.6GHz 16GB 2133MHz LPDDR3 memory 256GB SSD storage Intel Iris Plus Graphics 640 Two Thunderbolt 3 ports Backlit Keyboard - US English Accessory Kit Force Touch trackpad Software macOS Sierra Photos, iMovie, GarageBand Pages, Numbers, Keynote and it's going for $1,743.03 with taxes included. If the MacOS isn't compatible with PT, then that would def be a problem. |
I´m just asking because you say you are on a budget and if you should have a 2011 MacBook Pro with an i7 Quad Core processor the most affordable solution would be just to upgrade your Ram and maybe your internal drive to any faster solution. Means, if your MBP has an I7 Quad Core processor you are ready for PT12 actually. If however your Macbook only runs by an i5 or even smaller CPU you probably will have to get a new, more powerful Macbook to get Pro Tools to work as it is supposed to. As for the memory, you know, 8GB Ram have been the official minimum requirement but in real life it has turned out that 16GB Ram are the adequate amount of memory for a fluently working Pro Tools system. It´s just that even Native PT12 now uses disk cache (like only HD did in the past) and so 16GB Ram are just the right starting point for a well working PT12 system nowadays. Simply from thousands of users´ experiences, you know? So given your MBP has got an i7 Quad Core processor already you only will have to invest about 280 bucks and you will be ready for PT12. Memory https://eshop.macsales.com/item/Othe.../1333DDR3S16P/ SSD https://eshop.macsales.com/item/OWC/S3D7E6G250/ You wrote about an external Lacie drive which certainly is working well as long it is a 7200rpm HDD connected via Firewire. Any 5400rpm HDD or any drive connected via USB 2 would be not really compatible with Pro Tools in the long run. If your 2011 MBP hasn’t got an i7 Quad Core processor you probably will need a newer, more powerful Mac. The basic requirements for a useable Pro Tools machine will be an i7 Quad Core processor 16GB Ram memory an internal drive with at least 7200rpm (if just HDD) and 256GB storage space. No Fusion drives! Further a second seperate drive for your Pro Tools sessions. Again 7200rpm HDD minimum. If external only via Firewire, USB 3 or Thunderbolt connection. No USB 2. You at first may check out the exact model of your current MacBook Pro. Click on the Apple icon in the left upper corner, click on About This Mac and finally click on System Report. Under About This Mac and in System Report you will find the exact data of your MacBook Pro. Then you can find detailed info about it there. https://everymac.com/systems/apple/m...acbookpro.html (Scroll down to find your specific MacBook Pro model and click on it for further info) If you should decide to go with a quite current MacBook Pro with one of those Apple Flash drives as an internal you could consider getting an 512GB Flash drive and skip any seperate, external drive for Pro Tools. With those super fast Apple Flash drives you can work with the internal only if you have not more than 20-25 tracks in particular. If you are looking for a new machine and you are on a budget you even might check out the Apple Refurbished store. https://www.apple.com/shop/browse/ho...macbook_pro/15 Just mind to go with an i7 Quad Core processor and 16GB Ram at the least (and no Fusion drive). The best of success to you, VRW |
Yeah, Apple officially set the limit to 8GB Ram but as you might read on
https://everymac.com/systems/apple/m...acbookpro.html all of the 2011 MBP models can be upgraded to 16GB Ram with 3rd party Ram. This should be no problem actually. It´s the type of processor which will be the key as for the use with Pro Tools. Quote:
http://avid.force.com/pkb/articles/e...m-Requirements If you are on a budget it makes seven more sense to go with an older MBP model which at least got an i7 Quad Core processor. I have had i5 MBPs and i7Quad MBPs myself with PT12. Believe me, I know what I´m talking about. You better get the i7 Quad. Anyway. All the best to you. Cheers. |
Would you please give us complete specs of what you have now? You may be able to make do with what you've got with the upgrades I mentioned (which you can do yourself). You can never have too much disk space as ideally you don't want to use up more than 75-80% of a drive. Remember that all your programs and plugins (except for samples) will reside on that drive. Almost forgot - any Mac with USB3 ports will have issues with your iLok; those have been known. The usual remedy is to use a powered USB hub between the computer & iLok. |
Thanks a lot for all of the great info!! I appreciate your input. my current mbp has the core i5 2.4GHz. So I should def go with a i7? ok thanks. going to look into it. |
It is NOT a used machine. It is a new machine with a discounted price for college students. ( I think it's only like $100 off original price ) it's directly from apple.com. Here are my current specs: Apple MacBook Pro 13" 2011 Core 15 2.4GHz 500GB HARD DRIVE 4GB RAM |
$1200 will buy a LOT of beer & pizza. |
Cannot purchase Pro Tools 12. HELP! | Grant_miller1 | Licensing & Accounts | 17 | 11-12-2015 12:23 AM |
Need Help on what Pro Tools to purchase | Vantae | Pro Tools 10 | 5 | 09-01-2012 07:18 AM |
Which pro tools to purchase? | Tennyson | Pro Tools 9 | 23 | 04-06-2011 07:52 AM |
Pro Tools 9 purchase help. | dougens | Pro Tools 9 | 4 | 11-24-2010 11:11 AM |
Pro Tools Purchase | Brianlykaios | General Discussion | 2 | 06-17-2010 02:23 PM |
