Mac doesn't turn off properly
When I try to turn my Mac off, it closes all applications except Finder, which leaves blank desktop and Dock stay forever. So I have to turn it off with button. This problem began to appear since Mavericks.
I guess Pro Tools is involved in this issue, because Mac seems to turn off OK if I don't start Pro Tools or put it to sleep before shutting down. |
Re: Mac doesn't turn off properly
I noticed this also on my 2015 mbp. I found logging off first then shutting down resolving this.
im not afraid. . . YOU WILL BE. . . YOU WILL BE mike g. . . |
Guys I did this, removed core audio driver on Yosemite and El Capitan.
Problem solved. http://avid.force.com/pkb/articles/e...ling-HD-Driver |
One more graceful way of shutting down if you do get stuck like this is to fire up a Terminal window and "sudo shutdown -h now" - bit longwinded but kinder to drives etc!
Pete |
Very true. I did this for a long time until I realised it could be cured by driver removal.
When a Mac does this a lot of times it's due to something not shutting down properly - it could be software and it could even be a drive that went to sleep or has not properly been unmounted. I've seen that happen here a couple of times.
So, I was one of those guys who stayed on Snow Leopard for years after it no longer supported, but not long ago, I figured I’d jump up a few OS and get Yosemite. This was a massive mistake, not only is my pt 11 entirely unstable, totally glitching up, throwing “increase buffer setting” errors left and right on even simple small sessions (where before I could run massive sessions), but I’m also experiencing this issue, however I don’t own PT HD, so are there any fixes to this issue for native users?
2011 21.5 inch iMac 2.5 GHz quad-core intel core i5 16 gigs of ram OS 10.8.4 Pro Tools 10/11 M-Audio Fast Track Ultra 8r BX8A's Tons of software, lots of good mics, tons of storage space |
I recently went back to OSX 10.10.5 having tried it a couple of years ago and found it wasn't stable enough for production work at least for me. Don't remember the exact details. The reason I went back to it now is there were a couple of Waves plugins I wanted but that necessitated using the latest WLM s/w and that meant a minimum of Yosemite. Started having intermittent problems with my machine not shutting down properly. Fixed it on my iMac when I checked in Activity Monitor and found cpu usage of 150% in thread related to Spotlight. I put every drive in Spotlight's privacy mode and that cured that.
Or so I thought when I got my 2012 MacPro. Every drive in privacy mode in Spotlight so wasn't that. Right now until I get some money coming in I'm working off a pair of FW800 7200 rpm spinners for samples and recording. On the off chance these were the culprit I ejected them before shutting down and that cured this most recent experience. It's interesting that this only happens after running PT for any length of time over an hour or so. Digital Performer - no problem for shutting down the computer. But if I run PT - then it hangs on shutdown. Then I make use of the Terminal command referenced a couple of posts back. Also interesting is being able to access the Terminal from the Dock even though Finder isn't running anhmore. |
Yeah, it only happens to me after using PT for some measurable length of time.
What are the side effects of removing the core audio plugin?
C 24 doesn't work properly with HEAT | Blues Bird | Pro Tools 12 | 5 | 07-29-2015 09:24 PM |
DIGI 002 will not turn on properly... ??? | totallyvagenius | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 09-05-2007 04:00 PM |
reinstall doesn't work properly | redwine5 | Digidesign Hardware & Software | 1 | 01-10-2007 03:09 PM |
SRC doesn't add up properly | jimlongo | Post - Surround - Video | 10 | 02-18-2006 03:12 PM |
If my Mac DOESN'T TURN OFF ?? | hed | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 08-08-2005 11:40 PM |
