Old 05-15-2019, 12:21 AM
Craig Hume Craig Hume is offline
Default Mix and Control not working in Logic Pro X 10.4.4 after OS upgrade to 10.13.6
Hoping for some insight or maybe I've reached the end of the road with my Euphonix branded Mix and Control and Logic?
All working fine in Logic until recent OS upgrade to High Sierra 10.13.6. After this, although 'Logic Pro X' shows as the application in use in the top left corner of the Control window, no other functions are recognised and both units are dead. Both units show as 'My Surfaces' in the EuControl settings window on my mac.
EUCON latest 19.5 was downloaded as I believe I was on the previous version of 18 to try and rectify but still not working.
I'm a little out of touch with how far Avid are supporting this hardware with Logic these days so apologies in advance if this issue is well known.
Thanks.
Apple iMac 27-inch with Retina 5K , 3.1GHz 6-core 8th-gen. Intel Corei5 ,8GB, 1TB FD, Radeon Pro 575X z 4GB
High Sierra 10.13.6
MOTU Ultralite MK3
Logic Pro X 10.4.4
Old 05-15-2019, 07:46 AM
EddieJones's Avatar
Default Re: Mix and Control not working in Logic Pro X 10.4.4 after OS upgrade to 10.13.6
19.5 was supposed to fix Mackie Control. We are working on a quick 19.5.1 release, please PM me with you email and I can get you a version to test this with as soon as we think we solve it.
Old 05-15-2019, 08:06 AM
Thanks Eddie. I'll PM you. However not sure what Mackie Control is to be honest!
Old 05-15-2019, 09:02 AM
EddieJones's Avatar
I'm sorry...reading too many posts at the same time. Logic is EUCON, not Mackie Control..so ignore my last comment.
On the Surfaces tab in EuControl are your units showing up in the right-hand column?
Old 05-15-2019, 09:09 AM
No worries.
Yes both units show up in the RH column in the EU Control Surfaces Tab and any movement of faders make the lights on my router flicker so it would seem general comms are OK. Also when you change apps on the iMac, the 'Control' screen changes to show the current app in use.
I'm assuming it stopped working after the OS upgrade as I can't recall anything else significant that was changed.
Old 05-15-2019, 09:21 AM
EddieJones's Avatar
First thing to try is to uninstall and reinstall. Use the 19.5 installer and select remove all Apps and remove prefs. Then reboot and install EuControl again and add your surfaces. Let me know if this helps.
Old 05-16-2019, 12:42 AM
Thanks Eddie. Will get that done today.
Old 05-16-2019, 02:43 AM
I followed your instructions as above but still no response from Mix or Control.
Although I don't recall ever having to make or change any settings in Logic to get these devices working with Logic, I am wondering if the error is there somewhere?
Old 05-16-2019, 07:36 AM
EddieJones's Avatar
I don't think there's anything specific. Have you checked the settings in the EUCON Application Setup Guide?
Old 05-17-2019, 01:09 AM
I'm going to check that today Eddie. Thx.
Strike 1.5 upgrade - not working because of iLok-working now gryphondale Virtual Instruments 0 01-27-2008 09:23 AM
Logic Control Hui Emulation working in Panther? kirkgale Pro Tools TDM Systems (Mac) 1 01-08-2004 07:23 AM
anyone have HD w/PT 6 working with Logic control ........... Seller Pro Tools TDM Systems (Mac) 1 03-02-2003 04:23 AM
Logic Control to control Pro tools : Brilliant !! PGrealy 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 7 05-10-2002 11:46 PM
Logic Control to Control Protools PGrealy 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 05-07-2002 08:28 AM
