Go Back   Avid Pro Audio Community > Pro Tools Software > Pro Tools | Intro Discussion
Old 02-11-2020, 11:18 AM
Dominatoruke Dominatoruke is offline
Default Delete Inserts?
The manual doesn't seem to cover anything regarding deleting of inserts. Can inserts be deleted or is this a limitation of PT First?
Dominic,
Dell XPS 8700 Desktop - 16gig RAM, Intel (R) Core (TM) 4790 [email protected] GHz - Windows 10. Focusrite Scarlett Solo interface.
Pro Tools First
Old 02-11-2020, 12:08 PM
Default Re: Delete Inserts?
If you mean "remove an insert slot", then no(an empty insert slot uses no power and has zero affect on audio). You remove a plugin from the slot(but the slot remains). Removing the plugin is as simple as inserting one. Click on the slot and select NONE and the plugin on that slot will be removed. I recommend spending a little time on youtube watching some "getting started with pro tools" videos to help you in learning your way around
Old 02-11-2020, 01:58 PM
Duh! Embarrassing. I have found the getting started videos very helpful.
Dominic,
Pro Tools First
Mbox Pro "Inserts" vs "Hardware inserts" GoGoJoe FireWire & USB Audio Interfaces (Win) 30 01-21-2016 03:39 PM
To Delete or Not to Delete...that is the question DonaldM General Discussion 14 11-06-2013 04:52 AM
OMNI inserts only for mic pre , or used as master buss inserts as well Weird Audio Pro Tools TDM Systems (Mac) 3 11-14-2012 09:27 PM
key command to delete all inserts evan brass Pro Tools 9 1 03-12-2012 03:03 PM
In case delete region, my PT 5.1.3 delete all regions on track. What is it? kwarkot Post - Surround - Video 0 12-04-2002 12:38 AM
