mac pro, leopard, PT 7.4, noise attack
I have a production going in my studio, that does not work with my G4 powerbook. so i bought a mac pro. Now the mac pro came with leopard an its really fast, but i have one big problem: when recording or playback is running - the playback stops and first makes a noise, like a very fast loop, then ALL channel give their maximum output in a very high and agessive niose. that makes your head explode, if you wear headphones. i have tried different playback-engine-settings, but no matter what i do, cpu-usage is almost zero. i tried internal and external - hds. both the same. i also switched the firewireports from front to back. still same result. monday is the next production-day. do i really have to switch to logic till theres a leopard-update? or is this a known, fixable thing? a friend of mine told me, he had the same error, with a different noise-sound. by the way, the error massage is "increase your buffersize..." i guess 9136 or something. i mean, this mac should do 14 channel, 3 plugins with any buffersize... thanks a lot, greetz, florian Mac Pro Quad 2,66Ghz, 3GB ram, PTLe 7.4, Duende... |
Re: mac pro, leopard, PT 7.4, noise attack
ProTools läuft noch nicht auf Leopard. Um es Stabil zu kriegen, müssest Du Tiger installieren.
It all clicks and buzzes from over here! |
Spent last 3 day learning about buying my first mac- just walked in from picking up my mac pro. And yup, what I've learned is I made sure it didn't have Leopard installed. One guy had no problem with 7.3 and Leopard- most warned me that Leopard would be dangerous til they make upgrades in January.
www.jimsavage.net www.manyrainsmedia.com Mac Pro Late 2013, 3.7, 12GB, Apollo Twin, PT12, ADL 600, UA 2-1176, Mojave MA-200 |
Ok, thanks,
what about installing parallel desktop - win xp and run pro tools on win xp on leopard. does that work? anyone tried that? where and how do i get tiger? greets, florian |
Pro Tools won't run under Parallels. You can however install Windows XP under Boot Camp on an Intel Mac and run Windows from there. But frankly, your best bet right now on a Mac is to run PT under Tiger. Do it according to Digi's recommendations and it will be fine. There is absolutely no benefit to running PT under Leopard at this point. If you want Leopard for running other apps, then install it on a separate partition. But for now run PT under Tiger.
What is the best way to attack this? | jrhager84 | Post - Surround - Video | 2 | 10-25-2013 03:27 AM |
Is avid.com and the DUC under attack? | Carl Kolchak | General Discussion | 7 | 11-07-2011 05:41 PM |
about to have a heart attack!!!!!!!!!! | mickeymassacre | Windows | 3 | 06-16-2011 08:07 PM |
Rather Spectacular Mid-Show White Noise Attack! | Chris Johnson | VENUE Live Sound Systems | 2 | 03-16-2011 05:22 AM |
Mac Attack! | Aussie169 | General Discussion | 11 | 09-12-2005 05:30 PM |
