Can\'t get Trials to run for Pultec and SRC Plugs..
I am trying to run the trial versions of the Pultec and Slightly Rude compressor plug-ins before I make my selection from the PLUS option. I am still running LE6.4 so I have downloaded version 4 of the plugs. When I start PTLE, I am given the option for "Trying" the software. When I hit the "Try" button, it looks for and requests an iLok key. Starnge thing is that I used the same process for the Smack plug and the trial started fine. Also, the dialog says there are still 30 days in the trial.
Anyone seen this? Any help would be appreciated. |
Re: Can\'t get Trials to run for Pultec and SRC Plugs..
I am having the exact same Poblem, my trial of Smack also works, and is counting down from the 14 day trail.
will someone Please help us I'd like to test these Plugs before upgading to Le 7-plus G-5 dual 2.00ghz OS 10.3.8 Le 6.9 ram 512 Mark Star Nine Enterprises Inc. |
OK, I finally got through to Tech support and they were very helpful. Here's what I found...You need to download a "demo key" to your Pace iLok account. *To do this, just
hit the "Try button on the plug-in dialog, deselect the use iLok key check box, select internet authorization on the next screen. *It will then ask for your digi account info and then you log into your iLok account (in the iLok site which you were automatically sent to). *It will then do the rest. *Do this for each trial you want to run and you should be good to go. Hope it helps, Mike |
pultec pullin the plugs | cary chilton | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 10-01-2006 11:27 AM |
where to buy the pultec plugs cheaper? | cary chilton | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 05-17-2006 09:53 AM |
Is anyone using PULTEC plugs ?? | cary chilton | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 13 | 05-15-2006 06:11 PM |
Plugin Trials | spinboy | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 6 | 02-19-2006 07:27 PM |
plug-ins trials | josephk | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 09-04-2003 04:07 PM |
