Go Back   Avid Pro Audio Community > Pro Tools Software > Pro Tools 2018
Old 02-19-2018, 03:45 PM
paddyrfc paddyrfc is offline
Default Pro Tools 2018 install
Hope someone can help me with this, I tried upgrading to PT2018. I had PT12.6.1 & PT Express already. When I tried to upgrade I got the following message:
"Incompatible Pro Tools installation detected. Before installing Pro Tools 12, please uninstall Pro Tools or upgrade to Pro Tools 10.3.10 or higher"
I have taken the following steps to try and resolve but still keep getting the error:
Uninstalled PT Express
Uninstalled PT12
Cleaned Registry
Deleted any AVID\PT folder on C: Drive
Tried to install PT12.5 & PT 12.6 (same error)
I have researched this and have found other people have had the same problem with a OS reinstall the only suggested solution.
Does anyone have a less drastic solution.
Thanks
Old 02-19-2018, 07:35 PM
Default Re: Pro Tools 2018 install
Windows or Mac? When you uninstalled PT12, did you also uninstall the HD driver?(this is regardless of whether you have an HD license). If not, it could be the driver fooling PT into this issue(if on Windows, go to Control Panel>Uninstall a Program and look for Avid HD Driver and uninstall).
Old 02-20-2018, 03:35 AM
Thanks for the reply, I have uninstalled everything PT related (drivers, codecs, app manager) but no joy. I haven't uninstalled the plugins and virtual inst so will try that later.
AMD Phemon II X6 1090T Processor
20GB Ram
320GB SSD
Win 10 64bit
Akai EIE Pro
Pro Tools 2018
20GB Ram
320GB SSD
Win 10 64bit
Akai EIE Pro
Pro Tools 2018
Old 02-20-2018, 04:56 AM
Something that I found when I had a Windows system and doing uninstalls is to after you empty the trash is to reboot between each uninstall and registry cleaning. Back in the day I didn't have CCleaner - is that what you used or did you go through the registry manually?
Jack
QAPLA!
Old 02-20-2018, 05:27 AM
Did cc cleaner and reboot when a did the initial uninstall and numerous times after each failed install. I edit the registry manually a number of times. I am thinking at this stage that at solution will be a bit leftfield as none of the normal "remove program, clean registry, delete old folders" is working.
20GB Ram
320GB SSD
Win 10 64bit
Akai EIE Pro
Pro Tools 2018
Old 02-20-2018, 05:41 AM
Originally Posted by paddyrfc View Post
Drastic as it seems you might be looking at a Windows reinstall. Wipe the hard drive and all that.
Jack
QAPLA!
Old 02-20-2018, 06:02 AM
I have kinda resigned myself to that. I found a spare HD to do it on so I don't have to Wipe the main drive. Its a pain to have to run a separate HD just for PT but that seems like the only fix in the short term.
20GB Ram
320GB SSD
Win 10 64bit
Akai EIE Pro
Pro Tools 2018
Old 02-20-2018, 07:48 AM
The Weed's Avatar
The Weed The Weed is offline
When you get things installed and running smooth - before installing PT - make a backup image. Then install PT. If it's not working properly, just restore the image. And make an image when PT is working properly. I image nightly and before any install/uninstall/upgrade/update. I also have archived images I can go back to, such as Windows installed and all programs before PT and those needed for PT. I use Macrium Reflect, others like Paragon or similar.
non-union national read at a reasonable rate
Demos: brucehayward dot com
Source-Connect: brucehayward
Old 02-20-2018, 07:49 AM
Will do, thanks for the tip.
20GB Ram
320GB SSD
Win 10 64bit
Akai EIE Pro
Pro Tools 2018
Old 03-24-2018, 04:38 AM
Just an update, The only solution I could find was to do a fresh install of windows and then reinstall Pro Tools.
20GB Ram
320GB SSD
Win 10 64bit
Akai EIE Pro
Pro Tools 2018
Lost HEAT in 2018 Install zeeman Pro Tools 2018 14 11-23-2019 12:35 PM
2018 | install plugin path? chip_nelson Getting Started 8 03-31-2018 04:37 AM
First Air Instruments Bundle Install fails with Update to PT 2018.1 Wire57 Pro Tools 2018 14 03-29-2018 01:21 PM
PT 2018 all user shortcuts erased on install Cheesehead Avid S1, S3, Dock and Control 4 01-30-2018 01:59 PM
tried to update to 2018.1 on win8.1 but HD driver wouldn't install ~ufo~ Pro Tools 2018 1 01-29-2018 07:27 PM
