Error 6085 underflow Windows 7 PT9
Hi Friends-
Countless 6085 underflow errors. There is nothing plugged into my firewire port so this doesn't make sense. I'm using PT9 on Windows 7 64-bit. I've tried all sorts of suggestions that I've found on this forum. I will say that the underflow error is worse when I have a couple UAD-1 plugins active. Sometimes so bad that the session won't work at all. Here is my Sandra report. Anyone see anything glaring? SiSoftware Sandra Computer Model : System manufacturer P5E Workgroup : WORKGROUP Host Name : JoeBlow User : Joe Blow Processor Model : Intel(R) Core(TM)2 Quad CPU Q6600 @ 2.40GHz Speed : 2.4GHz Cores per Processor : 4 Unit(s) Threads per Core : 1 Unit(s) Type : Quad-Core Integrated Data Cache : 4x 32kB, Synchronous, Write-Thru, 8-way, 64 byte line size L2 On-board Cache : 2x 4MB, ECC, Synchronous, ATC, 16-way, 64 byte line size, 2 threads sharing Computer Mainboard : Asus P5E BIOS : AMI 0501 12/05/2007 Bus(es) : ISA X-Bus PCI PCIe IMB USB FireWire/1394 i2c/SMBus Multi-Processor (MP) Support : No Multi-Processor Advanced PIC (APIC) : Yes Total Memory : 4GB DIMM DDR2 Chipset Model : ASUS X38 Processor to I/O Controller Front Side Bus Speed : 4x 267MHz (1GHz) Total Memory : 4GB DIMM DDR2 Channels : 2 Memory Bus Speed : 2x 401MHz (802MHz) Memory Module(s) Memory Module : Crucial 1GB DIMM DDR2 PC2-8000U DDR2-1000 (5-5-5-18 3-23-6-3) Memory Module : Crucial 1GB DIMM DDR2 PC2-8000U DDR2-1000 (5-5-5-18 3-23-6-3) Memory Module : 1GB DIMM DDR2 PC2-6400U DDR2-800 (5-5-5-16 3-21-6-3) Memory Module : 1GB DIMM DDR2 PC2-6400U DDR2-800 (5-5-5-16 3-21-6-3) Video System Video Adapter : NVIDIA GeForce 7300 SE/7200 GS (2 PS3.0, 2 VS3.0 450MHz, 256MB DDR3 2x675MHz, PCIe 1.00 x16) Graphics Processor Storage Devices SAMSUNG HD400LJ (400GB, SATA300, 3.5", 7200rpm, NCQ, 8MB Cache) : 373GB (C:) (D:) (F:) (G:) (H:) SAMSUNG HD753LJ (750.2GB, SATA300, 3.5", 7200rpm, NCQ, 32MB Cache) : 699GB (E:) LITE-ON DVDRW SHW-160P6S (ATA66, DVD+-RW, CD-RW, 2MB Cache) : N/A (I:) Logical Storage Devices Hard Disk (D:) : 29GB (NTFS) @ SAMSUNG HD400LJ (400GB, SATA300, 3.5", 7200rpm, NCQ, 8MB Cache) Hard Disk (E:) : 699GB (NTFS) @ SAMSUNG HD753LJ (750.2GB, SATA300, 3.5", 7200rpm, NCQ, 32MB Cache) Hard Disk (F:) : 10GB (NTFS) @ SAMSUNG HD400LJ (400GB, SATA300, 3.5", 7200rpm, NCQ, 8MB Cache) Hard Disk (G:) : 5GB (NTFS) @ SAMSUNG HD400LJ (400GB, SATA300, 3.5", 7200rpm, NCQ, 8MB Cache) Hard Disk (H:) : 216GB (NTFS) @ SAMSUNG HD400LJ (400GB, SATA300, 3.5", 7200rpm, NCQ, 8MB Cache) Windows 7 (C:) : 99GB (NTFS) @ SAMSUNG HD400LJ (400GB, SATA300, 3.5", 7200rpm, NCQ, 8MB Cache) 3.5" 1.44MB (A:) : N/A Optical Drive (I:) : N/A @ LITE-ON DVDRW SHW-160P6S (ATA66, DVD+-RW, CD-RW, 2MB Cache) Peripherals LPC Hub Controller 1 : ASUS (ICH9) LPC Interface Controller LPC Legacy Controller 1 : Winbond W83627DHG Audio Device : ASUS (ICH9) HD Audio Controller Disk Controller : ASUS (ICH9) 4 port Serial ATA Storage Controller 1 Disk Controller : ASUS (ICH9) 2 port Serial ATA Storage Controller 2 Disk Controller : ASUS JMB368 IDE Controller USB Controller 1 : ASUS (ICH9) USB Universal Host Controller USB Controller 2 : ASUS (ICH9) USB Universal Host Controller USB Controller 3 : ASUS (ICH9) USB Universal Host Controller USB Controller 4 : ASUS (ICH9) USB2 Enhanced Host Controller USB Controller 5 : ASUS (ICH9) USB Universal Host Controller USB Controller 6 : ASUS (ICH9) USB Universal Host Controller USB Controller 7 : ASUS (ICH9) USB Universal Host Controller USB Controller 8 : ASUS (ICH9) USB2 Enhanced Host Controller FireWire/1394 Controller 1 : ASUS VT6306 VIA Fire II IEEE-1394 OHCI Link Layer Controller SMBus/i2c Controller 1 : Intel 801xx/63xx SMBus Printers and Faxes Printer : Microsoft XPS Document Writer (600x600, Colour) Fax : Microsoft Shared Fax Driver (200x200) Network Services Wireless Adapter 1 : NETGEAR WNA1100 N150 Wireless USB Adapter (802.11g (ERP), TKIP, 54Mbps) Power Management Mains (AC) Line Status : On-Line Operating System Windows System : Microsoft Windows 7 Ultimate 6.01.7601 (Service Pack 1) Platform Compliance : x64 Windows Experience Index Current System : 3.1 Performance Enhancing Tips Tip 2546 : Large memory modules should be ECC/Parity. Tip 2 : Double-click tip or press Enter while a tip is selected for more information about the tip. Here is my PCI Bus situation: SiSoftware Sandra Computer Buses Interface Version : 2.30 PCI Bus(es) : 6 PCIe Bus(es) : 4 System Bus 0 Type : PCI Multiplier : 1x System Bus 1 Type : PCIe 2.00 x16 2.5Gbps Multiplier : 3x Bridge : Intel X38/X48 PCI Express Root Port Device Connected to Port : ASUS GeForce 7300 SE System Bus 2 Type : PCIe 1.00 x1 2.5Gbps Multiplier : 3x Bridge : Intel (ICH9) PCI Express Root Port 5 Device Connected to Port : ASUS JMB368 IDE Controller System Bus 3 Type : PCIe 1.00 x1 2.5Gbps Multiplier : 3x Bridge : Intel (ICH9) PCI Express Root Port 3 Device Connected to Port : ASUS Yukon 88E8056 PCI-E Gigabit Ethernet Controller System Bus 4 Type : PCIe 1.00 x1 2.5Gbps Multiplier : 3x Bridge : Intel (ICH9) PCI Express Root Port 1 System Bus 5 Type : PCI66 Multiplier : 1x Bridge : Intel 82801IB/IR/IH Hub Interface to PCI Bridge (ICH9 A2) |
Re: Error 6085 underflow Windows 7 PT9
Well I'm no expert on this, but perhaps your mismatched memory might be an issue? Have you done each and every one of the AVID win 7 optimizations? Also, please explain your hard drive setup. Are they partitioned? Which do use for your PTools session data?
Desktop build: PT 2020.5 / Win 11 / i9-11900K @ 5.1GHz / 64GB / 4TB NVMe PCIe 4 / Gigabyte Z590 Vision D / PreSonus 2626 Laptop: PT 2020.5 / Win 11 / i5-12500H / 16GB / 1TB NVMe / Lenovo IdeaPad 5i Pro / U-PHORIA UMC1820 Ancient/Legacy (still works!): PT 5 & 6 / OS9 & OSX / Mac G4 / DIGI 001 Click for audio/video demo Click for resume |
Right, I know I have that mismatched memory thing. Maybe that is it????
I did EVERY one of the Avid Win 7 optimizations, and all of the elective ones too. My hard drive setup is that I have 2 physical hard drives. All data and sessions are on that drive E. Then I have a bunch of partitions on the other one, hence all the "drives". This is where several different operating systems live, including Windows 7. Long story on why that is. Anyhow, could that be problem? Thanks for the help! |
Bump for any other possible ideas
Disable this when running Pro Tools(at least until you get the problem solved. The you can bring this back and see if it causes the problem). Mis-matched RAM raises a flag to me as well and I would remove all 4 sticks and install 2x4GB of some major branded compatible RAM(and make sure timings show correctly with a new Sandra report). If nothing is on the firewire port, I would also try disabling that in Device Manager(or BIOS). BTW, why so many drive partitions? Personally, I would not partition any drive of 500GB or smaller, and I would only split a larger drive in half for "housekeeping". For sure, its not helping performance.
Thanks for the replies. Should I disable that adapter in the Device Manager? Is it not enough to just have it unplugged?
I'm going to address the RAM issue. I also am going to do away with some of those drive partitions. I'm running a couple versions of XP, one was exclusively so I could run my student copy of PT7 JUST so I could get cheaper OMF conversion...I'd boot in one side, convert the OMF from the client and then boot up in my regular side to work. Not useful anymore with PT9 thank goodness! One of the partitions happened because I read in some guide that you should have a separate partition for some sort of caching or something...I honestly just did it and forgot about it. The other partition is my tried and true XP running PT LE 7.4 cs2. It's very stable and being that I need it for my work I've gotta keep it until I'm positive this Windows 7 thing will work right. Thanks for the advice you two, anyone else want to chime in? |
As to the wifi, I would disable it in Device Manager for now. When you achieve solid performance, THEN try just unplugging it(the idea is to eliminate as much as possible until you reach the happy zone). Good on ya for keeping the old XP config, but I choose a slightly different method. There are several SATA drive cages available(from single to 4 slot) that install in place of unused 5.25" drive slots. These allow for swapping hard drives without tools, so I keep my system drive, a clone of my system drive, and the last solid working system drive(I actually have the one before that as well since I grab drives on sale whenever I see a great deal). I can also devote a recording drive to certain clients and just swap out recording drives as needed. The single slot(for your system drive) can be found for under $20 from Kingwin(newegg.com) or DatOptik(but don't worry about all this till you get the issues ironed out)
I've disabled the wifi in the Device Manager. I've double checked that I've followed ALL of the Digi Windows 7 Optimizations. Still having the the errors. New memory is on it's way. Oh, I wanted to add that the mismatched memory doesn't effect Protools in XP...
Any other ideas? Thanks! Last edited by snahster; 11-14-2011 at 01:57 PM. Reason: Added sentence |
Ok, got 2 sticks of 2 gig, crucial ddr2 PC6400 RAM. Still have the same problem. Anyone have any ideas? Is is my old motherboard??
Anyone? Am I in a deep black hole here? Should I try replacing my motherboard? It happens even when I remove the UAD-1 cards. I am running out of ideas here.
Buffer Underflow 6085 error (yes, another one) | dezwits | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 12 | 10-29-2012 06:55 PM |
-6085 Underflow error [003 Rack+, Windows XP) Please I need help :( | EkPa | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 5 | 02-05-2010 02:21 PM |
error -6085 buffer underflow | djlang59 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 05-02-2007 01:26 AM |
Error -6085 Underflow and other questions… | muzak13 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 04-24-2007 07:59 AM |
need help! error 6085 - buffer underflow? | timbologic | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 08-30-2005 10:47 AM |
