Buffer Underflow 6085 error (yes, another one)
Hello and good evening from a Pro Tools Newbie. Brand new machine, brand new Pro Tools 8.0.5 LE user with Mbox Mini 3g (all updated to latest version). I'm wondering what I'm missing to make those 6085 errors go away that pop up every 30 or so seconds.
Here's my Sandra report: SiSoftware Sandra Computer Model : Lenovo IdeaPad Y560p Workgroup : WORKGROUP Host Name : LenovoJKMH User : Jacco Processor Model : Intel(R) Core(TM) i7-2630QM CPU @ 2.00GHz Speed : 2.6GHz Cores per Processor : 4 Unit(s) Threads per Core : 2 Unit(s) Type : Mobile, Quad-Core Integrated Data Cache : 4x 32kB, Synchronous, Write-Thru, 8-way, 64 byte line size, 2 threads sharing L2 Cache : 4x 256kB, ECC, Synchronous, ATC, 8-way, 64 byte line size, 2 threads sharing L3 Cache : 6MB, ECC, Synchronous, ATC, 12-way, Exclusive, 64 byte line size, 16 threads sharing Computer Mainboard : Lenovo KL3 BIOS : Lenovo 3FCN19WW 02/11/2011 Bus(es) : ISA X-Bus PCI PCIe IMB PCMCIA USB i2c/SMBus Multi-Processor (MP) Support : No Multi-Processor Advanced PIC (APIC) : Yes Total Memory : 4GB DDR3 SO-DIMM Chipset Model : Lenovo Core (Sandy Bridge) Mobile DRAM Controller Front Side Bus Speed : 100MHz Total Memory : 4GB DDR3 SO-DIMM Channels : 2 Memory Bus Speed : 2x 667MHz (1.33GHz) Memory Module(s) Memory Module : Ramaxel RMT1950MD58E8F1333 2GB DDR3 SO-DIMM PC3-10700S DDR3-1334 (10-10-10-27 4-37-11-6) Memory Module : Ramaxel RMT1950MD58E8F1333 2GB DDR3 SO-DIMM PC3-10700S DDR3-1334 (10-10-10-27 4-37-11-6) Video System Video Adapter : AMD Radeon HD 6570M/5700 Series (400 SM5.0 650MHz, 1GB DDR3 1.6GHz 128-bit, PCIe 2.00 x16) Graphics Processor OpenCL GP Processor : AMD Radeon HD 6570M/5700 Series (400SP 5C 650MHz, 832MB DDR3 1.6GHz 128-bit) Compute Shader Processor : AMD Radeon HD 6570M/5700 Series (400SP 650MHz, 1GB DDR3 1.6GHz 128-bit) STREAM GP Processor : AMD Radeon HD 6570M/5700 Series (400SP 5C 650MHz, 1GB DDR3 1.6GHz 128-bit) Storage Devices Seagate ST9500325AS (500.1GB, SATA150, 2.5", 5400rpm, 8MB Cache) : 466GB (C:) (D:) eSATA-2 ExternalRAID (500.1GB, SATA300) : 466GB (G:) SlimtypeDVD A DS8A5SH (7.7GB, SATA150, DVD+-RW, CD-RW, 2MB Cache) : 7GB (F:) Logical Storage Devices Hard Disk : 200MB (NTFS) Pro Tools (G:) : 466GB (NTFS) @ eSATA-2 ExternalRAID (500.1GB, SATA300) LENOVO (D:) : 30GB (NTFS) @ Seagate ST9500325AS (500.1GB, SATA150, 2.5", 5400rpm, 8MB Cache) Hard Disk (C:) : 420GB (NTFS) @ Seagate ST9500325AS (500.1GB, SATA150, 2.5", 5400rpm, 8MB Cache) Pro Tools LE (F:) : 7GB (CDFS) @ SlimtypeDVD A DS8A5SH (7.7GB, SATA150, DVD+-RW, CD-RW, 2MB Cache) Peripherals LPC Hub Controller 1 : Lenovo HM65 LPC Controller LPC Legacy Controller 1 : Winbond W83687THF Audio Device : Lenovo Cougar Point High Definition Audio Controller Audio Codec : Realtek Semi High Definition Audio Audio Device : Lenovo Redwood HDMI Audio [Radeon HD 5600 Series] Audio Codec : ATI (AMD) HDMI Audio Disk Controller : Lenovo Cougar Point Mobile 6 port SATA AHCI Controller Disk Controller : Lenovo Standard SD Host Controller USB Controller 1 : Lenovo Cougar Point USB Enhanced Host Controller #2 USB Controller 2 : Lenovo Cougar Point USB Enhanced Host Controller #1 SMBus/i2c Controller 1 : Intel ICH SMBus Printers and Faxes Printer : Send To Microsoft OneNote 2010 Driver (1200x1200, Colour) Printer : Samsung ML-2525W Series (1200x1200, Colour) Printer : Microsoft XPS Document Writer (600x600, Colour) Fax : Microsoft Shared Fax Driver (200x200) Network Services Wireless Adapter : Atheros AR9285 Wireless Network Adapter (802.11g (ERP), AES-CCMP, 54Mbps) Power Management Mains (AC) Line Status : On-Line Battery No 1 : 100% Operating System Windows System : Microsoft Windows 7 Home 6.01.7601 (Service Pack 1) Platform Compliance : x64 Windows Experience Index Current System : 5.8 Any thoughts would be appreciated. The G drive to record to is new and is spec'd at 7200 rpm, access time less than 9ms. As far as I'm aware, it's set up for RAID0 (so no RAID, really). Anything else I may be missing? |
Re: Buffer Underflow 6085 error (yes, another one)
Bob |
Thanks for getting back to me. Before I buy another hard drive and still run into the issue - is it a problem that the internal hard drive on my laptop runs at 5400 rpm? I don't use this to record audio; only to run the application.
System drive at 5400 rpm is OK. Read up on the drive requirements for externals before dropping any cash...
Bob |
Thanks Bob, indeed - don't spend money if you don't have to...
So I borrowed a Lacie d2 Next Quadra from work (7200rpm, 16MB cache, 9ms access time), plugged in through eSATA port. No RAID on this thing, record, and within 10 bars I got the same error message: buffer underflow. So I'm guessing there's something other than the external drive that's causing trouble. Any other thoughts of what could be causing this? I have nothing plugged into any USB ports other than the MBox Mini, I have done all the Windows 7 optimization steps. Jack up internal memory? Replace internal disk as well? |
Have you disabled all networking? What is running in the background? Antivirus and such can kill you, so open the task manager and see what's running. Symantec can cause 6085 errors.
So here's something I found out last night as I was A/B-ing my own drive (RAID0) and the one from work. In spite of the fact that the message tells you to decrease the H/W buffer size, INCREASING it (from 128 to 1,024) actually worked with the none-RAID drive: I was able to record for several minutes at a time without the 6085 error. Symantec has always been disabled, as were all network adapters. I'm hoping this stays resolved.
Thanks for the help guys! I'll try to return the favor once I get more experienced with the actual system. |
I'm not 100% certain of this, but I think I recall Digi mentioning that simply having a RAID attached to the system could be problematic, whether it was in play for the session or not. Can anybody verify or debunk my recollection? Is there some reason why you wouldn't want to format the existing drive as NTFS non-RAID? As far as the decrease buffer messages, were you paying close attention? There are both increase and decrease buffer messages, which are similarly numbered and read about the same at a glance. Bob |
I only have one eSATA port on my machine, so I had my (RAID) drive plugged in - trouble. Turned off machine, swapped drive to be the work (non-RAID) drive - no trouble.
Work around for Buffer Underflow error 6085 | Bretski | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 6 | 05-22-2013 04:52 AM |
Error 6085 buffer underflow SOLUTION (for me) | mozment | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 08-25-2011 11:31 AM |
Audio buffer underflow -6085 error on mac pro | paul mccarthy | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 30 | 02-21-2011 10:25 AM |
error -6085 buffer underflow | djlang59 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 05-02-2007 01:26 AM |
need help! error 6085 - buffer underflow? | timbologic | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 08-30-2005 10:47 AM |
