Go Back   Avid Pro Audio Community > Other Products > The Drum Room
Old 04-25-2011, 12:48 AM
lespaul1963 lespaul1963 is offline
Default EZ Drummer & Pro Tools 8.04 Help
I am having some problems getting my EZ Drummer and Pro Tools to play nice together. I'm using a Windows 7 PC. I create a stereo instrument track and open EZ Drummer from one of the insert boxes for that track in the grid view. I select a groove in EZ Drummer and when I try to drag and drop, nothing happens. I arm the record button on the track and on the transport controls (record/play) and try to record the groove on the track as it plays and I get nothing. EZ Drummer runs, the level meters show a signal, but nothing records and no "notes" appear on that track. I have an Axiom Pro25 MIDI controller and I have no problems with that and the virtual instruments recording and playing back. Is my issue with EZ Drummer with the software or the user? What can I do to solve this? Help.
Old 04-25-2011, 08:35 AM
Default Re: EZ Drummer & Pro Tools 8.04 Help
A couple of things to check; ezdrummer should go in the first insert slot(slot A). The stereo instrument track should be in NOTES view. You should be in GRID mode for drag&drop with the grooves(loops). It all works good for me. BTW, you might want to image your system and then update to either cs2(for 8.0.4) or go to 8.0.5 as 8.0.4 has some timing issues during recording(cs2 solved it EXCEPT for a 48K session).
Old 04-25-2011, 03:10 PM
Not sure what imaging is, but I followed the rest of your suggestions, including the update and no dice... same as before. Is there something else I need to toggle on/or off...not sure what to do.
Old 04-26-2011, 04:49 PM
Re. imaging(and drive cloning), read this thread: http://duc.avid.com/showthread.php?t=299897 and check out Acronis True Image(for PC users anyway).
Old 06-05-2011, 12:43 PM
Julia B Julia B is offline
I use Acronis. You will have to first install it on your system. However, like all of these types of programs they like to do constant backup and will bring a quad core to its knees. So please remember to do the following:
* Make a backup of the Acronis download.
* After you do your initial clone, you'll see an option to create a bootable CD that has the Acronis software on it.
* uninstall the software.
* from this point on whenever you do a drive clone, do it from the bootable disk.
Store your clones to an external USB drive like a WD My Book or something like that. 2TB isn't that expensive. You only need it connected when you're cloning.
Model : Intel(R) Core(TM)2 Quad Q6600 2.40GHz
IDC : 4x 32kB, Synch, Write-Thru, 8-way, 64 byte
L2 : 2x 4MB, ECC, Synch, ATC, 16-way, 64 byte line sz, 2 thds sh
Mainboard: DFI Inc. INF P35-R
BIOS : Phx Tech, LTD 6.00 PG 03/11/2008
Bus(es) : ISA X-Bus PCI PCIe IMB USB i2c/SMBus
MP APIC : Y
Tot Mem : 3.25GB DIMM DDR2 (WinXP)
Chipset: Intel P35/G33/G31 Proc
Front Side Bus Spd : 4x 266MHz
Mem Bus Spd : 2x 399MHz
(C:) : (250GB, SATA, 8MB Cache)
(D:) : (250GB, SATA, 8MB Cache)
EZ Drummer w/Pro Tools 11 Stys64 Pro Tools 11 19 01-01-2015 08:48 AM
Pro Tools SE and EZ Drummer Kirkmeister Pro Tools SE and Essential (Win) 1 02-03-2013 04:57 PM
Superior drummer 64 bit in pro tools 9 Raoul23 The Drum Room 3 07-19-2011 11:00 PM
Pro Tools 8 and EZ Drummer - Help! Kelly Vaughn 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 12-17-2009 11:12 AM
Superior Drummer + Pro Tools Mike1983 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 10-17-2009 04:56 PM
