Go Back   Avid Pro Audio Community > Other Products > The Drum Room
Old 01-28-2010, 08:02 AM
Lamprocles Lamprocles is offline
Question Strike crash cymbal cuts out during double bass
Hi everybody! I'm new to these forums and have already learned a lot from all the great threads within.
My question is about Strike. I'm using the Heavy Metal kit, and created some patterns. One of the patterns has double bass throughout with one crash hit per measure. The crash hit cuts out, and it appears to be because of the double bass. If I remove the double bass drum from the pattern, the cymbal rings out as it should.
Any ideas why this would happen? And possibly a fix?
Thanks!
Old 01-29-2010, 09:52 PM
Default Re: Strike crash cymbal cuts out during double bass
How much RAM are you using? I've never had this happen on ezdrummer or SD2, but I haven't used Strike (yet). You could mute the kicks and bus the crash to an audio track and record it(then mute or remove it from the instrument track).
Old 03-08-2010, 06:37 PM
Talking Re: Strike crash cymbal cuts out during double bass
Plenty of RAM (4 GB, not nearly using it all). I figured it out though in case anybody gets the same problem, should have seen it earlier.
Changed the Polyphony (voices) in the Strike Configuration box from 16 (the default I think) to Unlimited.
32 or higher also worked.
I didn't realize how many voices were actually involved when just the bass drum and crash cymbal were playing. I wonder if this is because of the amount of virtual mics that are used for each instrument? Not imperative but I'd love to hear your opinions about that...
Windows XP Pro, Digi Rack 003, LE 7.3
Strike Mix View Missing Crash Cymbal mrgroovy Virtual Instruments 0 05-22-2013 06:34 PM
Strike Cymbal Tricks RussUK Virtual Instruments 4 05-18-2009 03:36 PM
Cymbal Crash Rolls??? jordan23 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 10 03-18-2004 12:42 PM
Cymbal Crash Rolls??? jordan23 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 03-15-2004 07:46 AM
guitar eq cuts for bass? village1 Tips & Tricks 1 11-06-2002 03:12 PM
