Headphone Mix
Isn't there a key command for copying the the fader positons on the mixer to the sends for the purpose of a headphone mix?
http://www.soundclick.com/sneakypete |
Re: Headphone Mix
I'm not aware of one.
However the following hints may help, depending on what you'd like to achieve with your question: - If you set the channel sends to post fade, every channel fader change will also affect the headphone mix - Once set up, a send can easily be copied to another track by dragging it while holding the alt/option key
Mac mini 2018, i7 3.2 GHz, 32G RAM, 1TB SSD Mojave 10.14.6, PT 2020.5 Vanilla, several Waves V13 and some Massey plugins PreSonus Quantum, Avid S1 & Control, MC Transport, Tascam HS-P82 Field Recorder |
Re: Headphone Mix
HD there is... LE there is not.
HD only Choose Edit > Automation > Copy to Send. Seems a pretty wierd thing not to include.... Maybe its in the new DV toolkit..Altough a lot of money for a simple function |
Eleven Rack headphone port versus MBOX and other interface headphone ports | World Spirit | Eleven Rack | 3 | 02-12-2012 11:34 PM |
headphone amp | tuffy21 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 6 | 07-01-2005 11:05 PM |
OT - headphone amp | euphjazz | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 10 | 01-16-2005 03:24 PM |
headphone mix | MR808 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 07-19-2003 11:29 PM |
Headphone Impedance and the 001 Headphone amp | Mark_Knecht | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 6 | 05-15-2002 12:22 AM |
