Old 08-15-2004, 07:33 AM
mr_dude mr_dude is offline
Default How do I get rid of startup popup requests?
Whenever I start up ProTools, I get the following requests:
Authorize/Quit:
- VocAlign Project LE
- DVToolkit
- DigiTranslator
These were demos that came with my rack002 system that I tried, but do not want at this time. Each time I start up ProTools I have to select "Quit" for each of these. It's not that big of a deal, but it does bug me. Any suggestions on how to get ride of these?
Any help is much appreciated.
Old 08-15-2004, 09:49 AM
2224 2224 is offline
Default Re: How do I get rid of startup popup requests?
Authorize/Quit:
- DVToolkit
- DigiTranslator
boot drive then library then application support then digidesign then plugins then remove the offending plugins.
simple.
JAMAICAN I IS
2008 2009 and 2010 Mac Pro 8 core with
64 GIG memory with 9 terabyte of hard drive space
blue ray player
HDX 1, 2 16X16 interfaces
sync I/O.
Old 08-15-2004, 01:11 PM
I'll try that. Thanks.
Old 08-15-2004, 02:41 PM
byteme byteme is offline
this will not get rid of digitranslator or dv-toolkit. I don't know how, but if someone does please share.
Old 08-15-2004, 07:40 PM
A2D D2A A2D D2A is offline
You have to re-install PT, there was a warning that shipped with 6.1 and higher that explained this.
Before Installing the DV Toolkit Demo Please Note:
Contrary to information included with the DV Toolkit PDF electronic guide, the DV Toolkit Demo will replace Pro Tools LE 6.1. At the end of 30 days, DV Toolkit demo users will need to either:
1. Purchase and authorize DV Toolkit (an iLok USB authorization key is required).
2. Uninstall the demo and re-install Pro Tools LE 6.1. Please keep your Pro Tools LE 6.1 CD-ROM handy for this purpose.
From available selections, please choose "Repair."
Old 08-15-2004, 09:11 PM
Avid's Avatar
Avid Avid is offline
Administrator
That's true on 6.1-6.2.3, but not with 6.4.
From the DV Toolkit Guide version 6.4:
Removing DV Toolkit for Pro Tools LE
If you let a demo version of a DV Toolkit component expire, you should remove it from your system. Otherwise, each time you open Pro Tools you will be prompted with a message that the component has expired.
Pro Tools LE 6.4
To remove DV Toolkit on Macintosh:
1 - Open the Pro Tools folder on your Startup drive (Library/Application/Digidesign/ Pro Tools).
2 - Drag the files for DV Toolkit and DigiTranslator to the Trash:
• TimeCode.dll (Pro Tools for DV Toolkit)
• OMF.dll (DigiTranslator)
3 - Open the Plug-Ins folder on your Startup drive
(Library/Application Support/Digidesign/Plug-
Ins).
4 - Drag the Broadband Noise Reduction LE (DINR LE) plug-in to the Trash.
5 - Drag the VocALignEX plug-in to the Trash.
6 - Empty the Trash.
Pro Tools LE 6.2.x and Lower (Macintosh Only)
Removing DV Toolkit for Pro Tools LE 6.2.x and lower on Macintosh also removes the Pro Tools LE application. To reinstall Pro Tools LE 6.2.x on Macintosh, reinstall Pro Tools from the Pro Tools Installer CD-ROM.
(additional details in manual)
Administrator
Old 08-16-2004, 02:21 AM
Guerrilla Tech Guerrilla Tech is offline
look here thread
Old 08-17-2004, 05:05 PM
Excellent, that worked! Thanks.
What does this popup mean?? Taliq Pro Tools TDM Systems (Mac) 6 08-18-2008 03:06 AM
Popup assualt sonorelli Pro Tools TDM Systems (Mac) 2 01-09-2007 08:43 AM
Bugs, feature requests and tip requests! Basil Rush Pro Tools TDM Systems (Mac) 6 12-07-2005 08:21 AM
No nudge popup menu mark linett Pro Tools TDM Systems (Mac) 0 01-18-2000 06:47 PM
No DSP usage popup afj Pro Tools TDM Systems (Win) 0 01-14-2000 02:03 AM
