Changing the click track voice
How do I change the click track voice. Right now I can only get a piano note for my click. I don't know if it's getting the piano sound from my computer somewhere, or if it's just part of ProTools, but I can't figure out how to change it.
Re: Changing the click track voice
The click track sound SOURCE is NOT part of PT. PT is sending a midi signal to whatever midi sound source you have avalable. If you don't have any external sound modules, PT will use whatever general midi device that is avaible to the system. Most sound cards have a standard set of general midi sounds and that is most likely what you are hearing.
You can also search this formum for this subject. It has been talked about several times before. Good luck, G~
Musician/Electrical Engineer San Diego, CA |
Thanks G.Roots. I knew it had to be something simple.
Just in case anybody else wants to know what I did... I changed my Click Track output to Channel 10 in the Click Options window. I guess Channel 10 is typically used for percussion sounds. That gave me different drum sounds which I can change by changing the note value in the Click Options window. |
you're right on. i also believe that patch 116 or so is a woodblock. (116 out of 127 that is)
Jeremy Forbis |
help on changing voice in pro tools | Beng985 | Tips & Tricks | 3 | 07-11-2013 05:26 PM |
Changing click track tempos in songs??? | len-hallock | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 10-11-2009 01:17 AM |
Changing the tempo of my click track during the song??? | wavefade | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 04-13-2007 05:51 PM |
Changing meter and tempo of click track | mikegtrnut | Pro Tools M-Powered (Win) | 5 | 02-27-2007 12:54 PM |
Midi Click Track Changing Tempo? Tell it aint so. | heybluez | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 02-05-2007 06:51 AM |
