Old 06-21-2017, 02:41 AM
Versami Versami is offline
Default C24 Display Problem
Hi there,
I'm new in here :)
I have a problem with my C24. Two displays are not working, the backlight is ok but there are just squares... ?? (picture-link attached)
Even if it's connected to ProTools 12, the 3rd display is working fine...
Does anyone know what to do? Is it a hardware-problem, maybe a loose cable...?
Restart has no effect, firmware was updated...
Here's a picture:
Could someone help?
Cheers
Old 06-21-2017, 07:37 AM
YYR123's Avatar
YYR123 YYR123 is offline
Default Re: C24 Display Problem
Did you reset the unit? It should have a reset to defaults?
Picture didn't come through......Avid should sell those displays still, it's a current product
Daniel
Old 06-22-2017, 01:26 AM
Thank you! I just found the firmware reset but no button for something like a sysreset as Control 24 has...
image is attached...
Old 06-22-2017, 07:39 AM
YYR123's Avatar
Wow that does look bad, no other weird issues with lights on other parts of the board?
I'm thinking that it might indicate a power supply problem if you have other areas of your board seeing abnormal light problems
Do you have an active support plan? If so, it might be as easy as sending them an email and asking them if they have seen this issue.... because if you have an active support plan heck you're already paying for the support it doesn't cost you anything else to contact them
Daniel
Old 06-22-2017, 09:00 AM
Thank's for your ideas, but there is no problem with other lights on the board.
I've made a short videoclip in vegas mode...
https://www.dropbox.com/s/iqjvlbuj67...oblem.mov?dl=0
Actually I have no active support plan, so...
Old 06-25-2017, 02:55 PM
Thanks YYR123! I opened the board and made a little test. So the displays are working fine, even the flat ribbon cables. Hm???
Maybe there is something going on with the comm circuit board?
And no, I have no active support plan at the moment - do you think it's useful for something like that?
Old 06-25-2017, 02:57 PM
Ah, and there are no other light problems with the board or other weird things-
everything is working fine except the 2 displays...
Old 06-26-2017, 04:41 PM
YYR123's Avatar
Wow, it really appears that those strips are bad.
If I was feeling motivated I would swap the one working with the one that's not.
This would tell you if it's the driver or the actual display board.
But at this point it might be worth 30 bucks to actually call avid and have them troubleshoot it with you over the phone
Daniel
Old 06-26-2017, 10:01 PM
Yes, I already did that and all the cables and the 3 displays are fine...
The problem seems to be the comm board, I think I need to buy a new one
Yesterday I sent an email to the German support and hope they will sell me just the board so I can replace it...
C24 Led Display Problem Malinda Lowe ICON & C|24 2 01-02-2016 09:17 AM
003 LCD display problem frostyeve FireWire & USB Audio Interfaces (Mac) 3 10-19-2013 05:06 PM
002 display problem bishopqdog 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 04-06-2009 05:26 PM
Help--Display problem stickstome2 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 10 10-25-2003 11:40 AM
Audio Regions Display Problem & Grabber Problem markus44uk 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 03-25-2002 04:08 AM
