Old 12-21-2020, 01:22 PM
Jvadillo Jvadillo is offline
Default Dead E3 engine
Hi all,
One of my E3 engines is apparently dead, it boots all right and discovers both the s16 and the s3 surface but the engine picture on the devices tab appears greyed out with an exclamation sign and no audio passes through the console. Hovering the mouse over the engine icon gives a “not available” status on MAC address, I/O firmware version and network switch firmware version. A warning is on the bottom that states: “VENUE is currently waiting for connection to the E3 Engine I/O and the E3 Engine network switch”. Tried restoring a couple times with no effect, opened the engine and checked all cables, they all seem to be ok, checked the SD card on the auxiliary next to the mobo against the one on my other engine and they seem to be identical. Swapped the mobo between engines and same problem.
Obviously there’s some issue with the internal switch. Any help would be appreciated.
Regards
Old 12-24-2020, 02:59 PM
Kristo Kotkas Kristo Kotkas is offline
Default Re: Dead E3 engine
Hello, I believe the best way to go is as always, contact Avid Live Sound support.
Old 01-06-2021, 09:52 AM
Pacera Pacera is offline
Sounds like an internal AVB network card issue, wich usually mess up the entire system if it's the case.
Did you have a look under Windows at all the network cards ?
Did you verify that the internal AVB card got the proper ip adress to work with Venue System ?
Video Engine Fail "Waiting for the video engine to launch" oscar_wonderboy macOS 5 08-14-2018 01:22 AM
Playback Engine Issue (Won’t load session with chosen playback engine) MattyJones Pro Tools 11 0 11-02-2015 11:52 AM
Playback Engine>Current Engine issue Hunterkiss macOS 0 06-28-2013 01:14 PM
No m-audio interface in current engine (playback engine) SlicerSounds Windows 1 10-04-2012 12:27 AM
192 i/o almost dead? DaV- Pro Tools TDM Systems (Win) 6 12-16-2011 03:48 AM
