Old 05-12-2017, 07:12 AM
yoerik roevens yoerik roevens is offline
Default Re: Pro Compressor side chain bug
Originally Posted by Reckless Erik View Post
Just to clear things up a bit. When the send on the trigger track is deactivated the problems occur. If you create an empty track below with an active send it makes no difference.Attachment 8494
That's even weirder, although my guess is protools is not expecting any signal to the sc bus in this scenario either. What happens if you put a silent (not muted) -region on the second (C) track?
Also, do you have 'dynamic plug-in processing' enabled? Does it help if you disable that? (my guess is that without dynamic plug-in processing, protools will not deactivate anything when it 'assumes' there is no signal to be expected)
Old 05-12-2017, 08:46 AM
Reckless Erik Reckless Erik is offline
Placing a blank region/clip on the C track makes no difference. Neither does dynamic plugin processing. The reason I discovered this was by accident. I was printing some stems and the duck bus was deactivated. To my horror the stems were compressing when of course they should have been clean. Not what I wanted!
[email protected]
Newcomer Audio Post
MacBookPro 2.3GHz i7 16GB RAM OSX 10.15.7, PT Ultimate 2023.12 HDn, MTRX Studio, 2x Avid S1, PT Dock...
Mac M1 Studio Ultra 64GB RAM OSX 13.6, PT Ultimate 2023.12 HDn, MTRX Studio, 2x Avid S1, PT Dock...
Old 05-12-2017, 08:56 AM
Stig Eliassen's Avatar
Originally Posted by yoerik roevens View Post
Exactly, so it seems busses get de-activated when they have no input signal assigned to them. Makes sense, bu the pro compressor shouldn`t compress when there`s no active signal routed to it's SC input indeed.
So the OP is absolutely right. This behavior is incorrect.
No, that is not what I meant. The bus is active (how else would a second track/send feeding the SC have any effect?), but deactivating the source feeding the SC input of a compressor is equivalent to NO SC input.
Old 05-12-2017, 10:34 AM
...deactivating the source feeding the SC input of a compressor is equivalent to NO SC input.
As I said before, it's not the source that is de-activated but the send on that source track and if what you say above is true then why is the compressor reacting to the input signal and not to the SC signal?
[email protected]
Newcomer Audio Post
Old 05-12-2017, 10:56 AM
dwaynedelario dwaynedelario is offline
I believe I have seen the same behavior in Fabfilter's Pro-C2. If you assign a bus as the key input, the compressor will not see the sidechain until that bus is actively engaged in the session i.e. that bus needs to be active on a send or output for the plugin to recognize it. If you just use a random bus from your I/O that isn't used, it won't see the key input.
MacOS 12.4 / Pro Tools Ultimate 2022.4
Old 05-17-2017, 03:42 AM
This is what you guys are seeing, right?
https://www.dropbox.com/s/xo3dmpdm5q...31.42.jpg?dl=0
https://www.dropbox.com/s/zc599tlyd4...31.28.jpg?dl=0
https://www.dropbox.com/s/qwlcxufdfr...31.17.jpg?dl=0
Old 05-17-2017, 05:38 AM
This appears correct. My gripe is why the compressor is active when the side chain effectively sees no signal when the trigger bus is inactive.
[email protected]
Newcomer Audio Post
Old 05-17-2017, 06:08 AM
Gotcha. This scenario makes sense to me, but as said, I don't know if this is intended behavior. Inactive sends feeding the SC bus = "pulled plug" (in lack of a better analogy) = normal compression.
Old 05-17-2017, 08:46 AM
Hear you. As I am a remnant from the days of mixing consoles and patch bays I feel that disabling a bus/send is analogous to yanking out the patch cord that feeds the s/c on the outboard processor!
[email protected]
Newcomer Audio Post
Creating a side chain compressor lownotesinc Tips & Tricks 10 02-09-2012 01:40 AM
Is it possible to side-chain an EQ? Herkimer 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 12-03-2009 06:00 PM
Compressor side-chain how to? porkipine 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 01-15-2008 09:34 AM
How do I set up a Side Chain junglelabs 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 09-30-2007 10:49 PM
SIDE CHAIN EQ+COMPRESSOR COMPRESSING VOCALS mihau Tips & Tricks 2 10-19-2002 01:17 PM
