Old 09-15-2020, 11:50 AM
JoffreyR JoffreyR is offline
Default Bug : sync issue with video
Hi all,
I am using Pro tools 2018 and I have a strange issue regarding sync with video.
(I think this is a clock issue but I don't know how to solve it).
I have made several tests, and I still got the same result, so here is an example.
I want to add a music to a video. So I have checked the video settings (25 fps, 48.000 hz). The length of the video is 1min30.
Then I create a new session in protools with the same settings. I import the video. Everything goes well with the frames in the Edit Window and I have also the video window opened.
I
Then I add a music (the file is also setup at 48000hz) starting at 0:12 until the end. The music is matching exactly some key moments (00:56 and 1:10). So I am pretty happy.
And now the mystery happens.
I bounce to quicktime with the same settings as source.
When I want to play the video in a player (quicktime, VLC...) the video is no more sync with the music.
The music start 1 sec late and there is more and more delay (for example the music is 2 sec late from key moment at 56 seconds).
I tried to use another software to edit the video (Premiere Pro). and if I start the music at 0:12 (same as in Protools), the music do not sync at the key moments as in protools.
So that's a real mystery and a nightmare to compose. Because When I create a music sync with a video. In fact, the tempo is not right in reality, only in the DAW.
I have tried everything. Could you help me, you"re my only hope !
Strange Video Sync Issue? Cheesehead Post - Surround - Video 6 02-12-2015 09:47 AM
23.98 Video Sync Issue Cheesehead Post - Surround - Video 8 11-07-2012 03:02 AM
PT Video Sync issue - am I doomed? ergalthema 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 11-25-2009 07:34 AM
video sync issue in PTLE glankrudolph 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 01-18-2007 08:53 AM
Music video sync issue Studio Dweller Post - Surround - Video 17 12-01-2004 07:14 PM
