Go Back   Avid Pro Audio Community > General Discussion & Off Topic > General Discussion
Old 05-17-2009, 01:25 PM
bontay bontay is offline
Default Consolodation
Hey everyone,
Is there a way to UNconsolodate a region after it's been consolodated to gain access to the seperate parts again? I noticed some editing errors and want to fix fades in the original regions. Is this possible without having noted the names of each individual region making up the whole?
B
Old 05-17-2009, 01:28 PM
audiogeekzine audiogeekzine is offline
Default Re: Consolodation
go back to the playlist you made before you consolidated your edits.
@theaudiogeek
| www.EPICSounds.ca | www.AudioGeekZine.com | www.HomeRecordingShow.com |
Old 05-17-2009, 01:38 PM
There is no other playlist...I just replaced what was there with the consolidated file....is there a way of finding the original regions in the region list?
Old 05-17-2009, 03:37 PM
Can you open an earlier version of the session by going into the backup session file folder(this assumes you have Auto Backup turned on) so you might find a version before you consolidated the track? If you CVAN find a version with the un-consolidated audio, you could(in theory anyway) go back to your latest version and select import session data, and choose the track from the earlier version. I also believe its possible to re-spot regions by their time stamp(but I don't know how to do it) so you could restore some of the individual regions and redo the edits. This is a good reason to save multiple versions of any session(like save when all tracking is done, then when you start editing, save as "song edited", "song tuned", etc.).
Gigabyte X79/intel i7 3930K, 32GB RAM, Presonus Studio 1810C
I started in this business with nothing..........and I have most of it left
Old 05-17-2009, 05:46 PM
critza critza is offline
Dont know if you are on Mac or PC but the grouping feature is great when molding regions together, and not wanting to use alot of hdd space.
The grouped regions still have the same abilities as the consolidated region (u can use fades) but it does not count the space in between as an audio region, hence not taking up hdd space as a wave file. On PC it is Ctrl+Alt+G after choosing the regions you want to "consolidate/group" and then the same command to ungroup it.
You can also group several regions from different tracks.
