Unable to launch PTF in 9.2 anymore
I have been able to launch PTF when I re-started in 9.2 when I was using Jaguar and Panther. But ever since I installed Tiger, I have been un able to launch PTF. I get this message, "DAE error -228", even though I re-boot in native 9.2.
I have even tried to boot up using an external firewire hard drive which has nothing installed on it but the System Folder and PTF. Still get the same error message. I'm stumped. Any suggestions? [email protected] |
Re: Unable to launch PTF in 9.2 anymore
Just a guess, but I'd try a PRAM reset, and if that doesn't fix things, then try an Open Firmware reset of nvram, following either with booting into OS 9 of course.
Since the -228 error refers to PTF being not compatible with OS X and you're getting it with the FW drive, it seems to me that the only place left for anything to do with OS X would be the PRAM. PRAM does store things like kernel panic info for OS X. Perhaps Tiger lodges something which previous versions didn't, and it's this which is causing the DAE error in PTF. But this is just a guess.
Dual 2.0 G5, 10.4.6, PTLE 7.1, 002R |
I got that message after installing Tiger and an M-audio Transit interface (which doesn't work with PTF).
Check your Apple > Control Panels > Sound menu. Make sure that your inputs and outputs are set correctly. I had to reset mine to make PTF open. Good luck. |
Unable to launch! | bornheim | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 10-21-2010 08:20 AM |
Help needed Pro Tools won't launch anymore! | digidesigner | Pro Tools M-Powered (Mac) | 3 | 09-20-2007 06:13 AM |
PODs Sounddiver wont launch anymore | Lalaman | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 5 | 07-02-2003 04:59 AM |
unable to launch DAE | eli | Digidesign Hardware & Software | 3 | 11-24-2000 12:27 AM |
unable to launch DAE | eli | Digidesign Hardware & Software | 0 | 11-15-2000 08:32 PM |
