Old 02-25-2014, 10:54 PM
KoMa KoMa is offline
Default Set the 003 as slave
I'm using the Kemper Profiler via spdif with my digi 003 rack and Logic Pro X.
Unfortunately there is some crackle and other noises when doing this. I have no found out that in order to get the setup work I have to set the Kemper Profiler as the master and the 003 as slave.
Can anyone tell me how I can do this? Haven't found any usable info in the manual or goole. Do I need to buy an external wordclock for this or is there a different possibility to set the the 003 as slave?
Thanks for your help!
Old 02-25-2014, 11:19 PM
crizdee's Avatar
crizdee crizdee is offline
Default Re: Set the 003 as slave
Originally Posted by KoMa View Post
Why doesn't the 003 work as the master? It should be fine as long as the session and the kemper are set to the same frequency and the 003 and kemper are connected digitally both to and from each other and kemper set to slave!
Does it not work like this?
To set the 003 as the slave I guess you just need to set the kemper as the clocking source in the audio control panel for the 003 or Logic but I don't know logic that well, but what ever digital connection is coming from the kemper should be set to be the clocking source. Personally I wouldn't use an external device as a master as it can cause problems later when/if the device is not available to clock the session.
Chris
Producer, Engineer,
www.ukmastering.com
Old 02-25-2014, 11:41 PM
Hi Chris,
thanks a lot for your answer!
I wrote to the Kemper support and that's what they told me. I also remember hearing that once a while ago, before I used it via spdif, so the info seems legit.
As I'm not home right now, if I want to set the interface as a slave, do I do this in the hardware preferences of the core audio manager or in my daw?
I'm not too experienced with spdif, as you can tell
Old 02-26-2014, 11:00 AM
Go to Setup>Hardware and set Clock Source to SPDIF
Gigabyte X79/intel i7 3930K, 32GB RAM, Presonus Studio 1810C
I started in this business with nothing..........and I have most of it left
Old 02-26-2014, 11:43 PM
Thanks a lot mate!
Slave & LE mikevarela Post - Surround - Video 6 10-04-2009 04:37 PM
LE 6.4 as MMC slave? mozart999uk 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 01-09-2009 11:06 AM
PT 6.41 as MMC slave peterle Pro Tools TDM Systems (Mac) 0 04-17-2008 02:01 PM
korg d1600 being slave a slave to pro tools sbag MIDI 0 04-12-2007 06:50 AM
Can I Slave a Mac G4 To My Pc Big Koo 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 10 05-05-2004 01:59 PM
