Old 02-09-2018, 07:11 AM
adam79's Avatar
adam79 adam79 is offline
Default Mapping two keys to same note
I use vmpk so I can map the midi notes of VI drums to my computer keyboard. I'm trying to figure out a way to assign two keys to one drum; I want each tom to have two keys so I can do more realistic rolls. However, the vmpk key mapper won't allow me to enter two different keys for one midi note. Does anyone know how I can do this or if it's even possible? Thanks.
Old 02-09-2018, 12:15 PM
Stephen Bond's Avatar
Stephen Bond Stephen Bond is offline
Default Re: Mapping two keys to same note
Might be easier mapping the same sound to two different keys?
Stephen
Mac mini M1 2020 16Gb Memory- 256Gb Storage, Monterey, Pro Tools 2022.9, Focusrite Scarlett 2i2
https://www.waves.com/r/djgsi6
Old 02-09-2018, 12:21 PM
Not sure with keyboards, but this was easy to do on the M-Audio Trigger Finger(and it did make a huge difference in tapping in fills)
Old 02-09-2018, 01:03 PM
Stephen
That would eat up another kit piece slot in whatever drum vi Adam is using. And depending on what that vi is he could easily run out of slots.
Jack
QAPLA!
Old 02-11-2018, 07:55 PM
adam79's Avatar
Stephen
That's exactly what I'm trying to do.
Old 02-12-2018, 02:36 AM
What I mean is to have the same sound on two different keys rather than two different keys mapped to one sound.
For example, with a snare on D1 and a different snare on E1, change the sound of E1 to be the same sound as D1. Thus you can perform a roll using two keys.
Stephen
Old 02-12-2018, 04:02 AM
adam79's Avatar
Stephen
I'll have to go thru the different menus and find where I can make this change.
Old 02-12-2018, 09:36 AM
I'm not sure any keyboard allows for midi note assignment(other than the default). That's where a product like the Trigger Finger comes in as you have freedom to assign pads at will, so using 1 of the 5 "pages" of assignments to double-up the pads makes a ton of sense Once you've done that, you will never want to program drums from a keyboard again
Old 02-12-2018, 12:46 PM
I get what you're saying but TF isn't needed here. It's not the keyboard that needs to be changed here but the drum vi in use. In BFD3 for example if there's an open kit piece slot for example you could put the same snare drum in another slot and assign that slot to whatever MIDI key you want to trigger it. That way you could have the same snare drum sound triggered by two different MIDI notes/keys.
Jack
QAPLA!
Old 02-16-2018, 08:30 AM
adam79's Avatar
This sounds like the correct move.. So I need to go into the preferences of my Drum VI (Audio Assault Westwood) and assign the same sample to two different MIDI notes.. and then assign those identical notes to two different keys in vmpk.
Hopefully the preferences for Westwood are fairly self explanatory, as it lacks a manual. Worst case I can always ask the developer.
Thanks.
Mapping VMPK Keys to XPand2 adam79 Virtual Instruments 3 06-08-2022 08:59 AM
Pressed some keys now shortcut keys wont work (T,R to zoom etc) Falcon 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 15 06-11-2016 10:49 AM
> Midi per note output mapping Howardk Pro Tools TDM Systems (Mac) 1 02-28-2008 01:32 PM
Mapping Mapping Mapping! Please Digi, Hear Us... relaxo MIDI 0 11-03-2005 09:44 AM
off topic - MIDI note mapping questions davidp158 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 10-21-2003 08:29 AM
