Permission Error 5000 PT10
Hi All,
After a good few years out from mixing I'm going to be getting my feet wet again. Problem is once Protools 10 is open, if I try to create a new session it comes up with an error stating: Could Not Create A new document because you do not have appropriate access privileges (-5000) while creating "IO Settings". Seems very bizarre. If I open Pro Tools 11 everything works fine. Any ideas what I can do please? I need Pro Tools 10 to function properly and using Protools 11 all the time is not an option for me. Thanks, Jamie |
Re: Permission Error 5000 PT10
Perhaps this article from Avid Knowledge Base helps?
Hi Stig,
Thanks for your help so far. I had already looked at that links suggestions. Unfortunately creating a new user and loading Protools 10 within that user does not change the issue. The folder that the page mentions Macintosh HD/Users/Library/Preferences/DAE Prefs I cannot find on my laptop. Not sure if that could be the issue? I'm on OS 10.10.5 Hopefully someone can help me fix this as not being able to use Pro Tools 10 is a real problem. Jamie |
File Already Open With Write Permission (-49) Error | i hear dead people | Pro Tools TDM Systems (Mac) | 2 | 06-07-2007 03:08 PM |
-5000 error | MarkPresti | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 03-15-2005 06:43 AM |
error# -5000 | bluddbank | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 11-13-2004 08:28 AM |
Help with Error 5000 with M-box PT6.1.1 Le | M-boxNewbie | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 09-23-2003 02:13 PM |
Error #- 5000 while verifying your Authorisation Unknown Error Help!!! | Kitch | Pro Tools TDM Systems (Mac) | 10 | 08-12-2003 08:57 AM |
