Old 12-24-2019, 05:12 AM
DeButte DeButte is offline
Default Automation of Software parameters (Trilian and Omnisphere)using Novation Launchkey
I am able to control any parameters in Trilian and Omnisphere using the Novation Launchkey 49....no problem. Where the problem starts is when I want to write the automation in Pro Tools. Everything works fine except the automation doesn't get written. If I use my mouse, automation gets written.
Help!
DeButte
MacPro 2.8Ghz 8 cores, 12Gb Ram, Pro Tools 10, Eleven Rack, Mc Mix
Old 12-26-2019, 03:28 PM
Default Re: Automation of Software parameters (Trilian and Omnisphere)using Novation Launchke
Have you made all parameters automation-enabled?
Old 12-26-2019, 05:56 PM
Sure....from within Pro Tools (Automation Window, or Command 4) and from within Omnisphere also.
DeButte
Old 12-26-2019, 11:52 PM
Marsdy Marsdy is offline
Help!
The Novation is sending out MIDI continuous controllers which you have mapped to Spectrasonics parameters right? In which case I think you would need to record this as MIDI data on the relevant Instrument/MIDI track in PT.
Dave Marsden
UK
Old 01-15-2020, 05:24 AM
I think what you are mentioning is to make sure Midi Thru is checked. (under option in Pro Tools).....It is checked.
Again, I can control anything in Omnisphere with my keyboard (Novation Launchkey or mouse).
The problem is when writing (recording) automation in Pro Tools. The mouse action gets recorded but not the Novation keyboard.
With the Novation keyboard I hear the automation but it won't write in Pro Tools....tried in Logic......same thing.
DeButte
Old 01-15-2020, 02:27 PM
What I’m saying is Pro Tools automation, for example when you set a track to write/touch etc. won’t record parameter changes for the vast majority of VIs including Omnisphere AFAiK with a few exceptions like Air Hybrid. As far as Pro Tools automation is conferenced the parameters just aren’t recognised/mapped. If you want to automate the parameters for most VIs you need to assign them to MIDI continuous controllers and record those to MIDI/Instrument tracks as MIDI CC events.
Dave Marsden
UK
PT12, Novation Launchkey 49, Native Instruments Plugin MrBrendan Pro Tools 12 5 04-23-2015 02:23 PM
PT11 and Novation LaunchKey 49 hardwiredstudios Pro Tools 11 1 02-20-2015 01:52 PM
Cannot add Novation LaunchKey 49 MIDI keyboard to PT Ex axel76 Pro Tools Express on Windows 5 09-21-2014 09:45 PM
FS: Omnisphere, Trilian, and Stylus RMX ejwells Buy & Sell 2 09-16-2014 07:27 PM
Lost Omnisphere and Trilian Ludia Windows 4 11-10-2011 12:32 AM
