Re: AMD Barton
Re: AMD Barton
[QUOTE]Originally posted by jcoker:
[QB] [QUOTE]Originally posted by genebadd: [qb] ohh damned, did it again, belay that last message, dont worry the computer is still doing good, just some bad gouge, check you system bios: go to PCI configuration the go to PRIMARY VGA BIOS [PCI VGA BIOS CARD] make sure it says [AGP VGA CARD]. That last post was screwed up around the time I was writing about this agp stuff. Sorry Gene...you the man! I changed the above to AGP VGA CARD and the pc booted @ 2083GHz cpu speed (changed in the BIOS). However, Sandra still complains that the FSB speeds are too high for PCI, AGP, etc. So I don't know how long this speed will last. I did try the DaveC test and got 32 tracks. I probably could get more, but I gotta' get back to work [img]images/icons/smile.gif[/img] So the pc survived the DaveC test posted on the first page of the Allen pc thread. I tried the DaveC (v2?) test (seperate thread...with D-Verb) and got only around 12 tracks. Anyway, I hope this pc stays stable. I wish I knew why Sandra says the FSB speed is too high. Does Sandra still complain about that on your pc!? I guess I should still try the memory test. Anyway, I'll post to the DUC when I can test more thoroughly. Thanks again for your help! |
Re: AMD Barton
jcoker, you know im not to sure if she is still complaining, Ill let ya know tonight when I get home. I didnt see anything that caught my attention last night so im not sure.
Gene |
Re: AMD Barton
still complaing, I dont know why, im just gunna ignore it until something happens. Everything seems to be running fine except my cpu gets to hot when I turn the fan down. I guess I better get some better heat sink goo. the cpu speed is 2.08Ghz though. Does the job.
Re: AMD Barton
Re: AMD Barton
jcoker, ya, im talking about that heat sink paste between the cpu and heatsink. I heard something about some "arctic silver thermal paste" which is supposed to help drop the cpu a good ten degree's or so. I guess the stuff that came with the volcano fan isnt doing to well with you either. Ill give that other stuff a try. That fan is loud like a tornado.
Gene |
6.1 TDM with AMD Barton freeze | S.Holstebro | Pro Tools TDM Systems (Win) | 0 | 06-19-2004 11:40 AM |
Does the AMD Barton, work with A7V8X?? | golli | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 04-12-2004 06:53 PM |
What is a Barton core on the AMD chips? | stereocp | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 02-18-2004 10:05 PM |
A7N8X with AMD Barton - Anyone using it? | Carl Fuehrer | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 04-28-2003 05:33 AM |
AMD Barton overclock | SEBJOERG | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 22 | 03-29-2003 01:09 PM |
