#1691
Re: Best System for PTLE for under $1000.00
Allen [img]images/icons/wink.gif[/img] |
#1692
Hi guys!!!
I'm thinking about building an "Allen machine", but maybe upgrading some key parts What do you think about the new AMD Athlon XP 3200+ CPU with 400MHz Bus with an ASUS A7N8X Deluxe? NVIDIA nForce2 chipsets are good choice for a DAW? Thanks for your input |
#1693
#1694
#1695
The new P4's are coming:
"Pentium 4 2.80C, 2.60C and 2.40C processors with 800MHz Quad Pumped Bus and the Hyper-Threading technology support for $278, $218 and $178 respectively" http://www.xbitlabs.com/news/cpu/dis...512093746.html Looks like a better choice than the XP3200+, at least cheaper... |
#1696
just swapped out the case for better quality Enermax case with 350W PSU. Also swapped out Volcano 9+ for Volcano 11+ to handle XP3000+ and beyond. Price of system has gone down about 30.00 from last month, but not enough to squeeze the XP3200+ in there. Maybe next month.
#1697
#1698
Just wanted to pass this along to the DUC. AMD's new 64-bit processors are
out, but they aren't advertising this a lot. Below are a few links where you can go to view some of these machines. They mostly run on SuSE Linux, but I think MS has a version of Server 2003 and XP for these procs too. Dual cpu based systems start around $2,500 http://www.penguincomputing.com/store/altus-1000E.php http://www.polywell.com/us/rackservers/poly1u2c-0.asp |
#1699
Hey guys, I ran that mem86 program for over 11 hours with no errors. So im not sure. I would hate to think the motherboard is faulty since a few of us are having the exact same problem. Even though mem86 passed doesnt necessarily mean the board and ram are compatible with each other. Looking at A7V333-x memory list, it lists only 256 meg chips. Maybe two of those instead of one 512Meg. I Dont see why that would make a difference but at the same time I dont know why assus hasnt listed any 512 meg chips. I managed to get this board running stable by setting the multiple 14x and the freq mulitplier to something like 147/33 or something. Its running at 2.01 Ghz.
Still getting the same old warnings from sandra " FSB exceeds chipset rated FSB" "The AGP bus speed is too high. The AGP bus speed should not be increased over 75MHz" ( dont know why the agp bus would be to hi, its set on auto) "The PCI bus speed is too high. The PCI bus speed should not be increased over 36MHz" (maybe some one can clue me in on where the 36Mhz comes from. I think it might be awhile before I build up the nerve to go buy a couple more sticks of ram just to see if it works or not. Running out of ideas here. Anyone actually running a A7V333-X with a 2800xp chip and one 512 meg stick successfully with no problems? Does anyone know if there is a utility out there that can diagnose a bad board? I know its a long shot but it seems like there is software for everything now days. Good luck, Gene |
#1700
If you are running stable at 2Ghz what is the problem? Forget about Sandra. Sometimes she is just a .... [img]images/icons/grin.gif[/img] Just run it for awhile and see how things go. Allen [img]images/icons/wink.gif[/img] |
Pro Tools-qualified desktops outdated??? | robotboy | Windows | 4 | 05-28-2013 05:02 PM |
HP Desktops? | whatwhat | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 7 | 04-29-2009 09:33 AM |
HP Desktops in LE?? | finman29 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 10-06-2008 11:06 AM |
Pro-Tools and RAM Drives. Laptops/Desktops - Possible? | epu | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 04-13-2008 09:34 PM |
HP Desktops | my cardboard box | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 04-05-2004 07:27 PM |
