Old 08-05-2020, 01:43 PM
senghor senghor is offline
Default Problem with instrument tracks
Hi.
I have a problem with instrument tracks.
Often ie. clap or bass won't play at all, and suddenly in a middle of a session they start to play. I am confused.
I have to copy my instrumental tracks to a normal track.
Have anybody have this problem. How to solve this?
Thanks.
Win11 Pro
Intel i7-12700K @3,6GHz, RAM 32GB
UAD Apollo and pre-amps, Pro Tools 2023
lots of plugins
Old 08-05-2020, 02:56 PM
DetroitT's Avatar
DetroitT DetroitT is offline
Default Re: Problem with instrument tracks
My crystal ball is empty.
Old 08-05-2020, 03:01 PM
capt kirk capt kirk is offline
You got mutes written into template automation or something?
www.kfaudio.ca
Old 08-05-2020, 03:03 PM
lesbrunn's Avatar
lesbrunn lesbrunn is offline
Originally Posted by senghor View Post
Hi.
Thanks.
Hi senghor,
There are many things that can make PT unstable, and you will have to eliminate possible causes one at a time. The main culprit could be incompatible plugins. Have you trashed your prefs? That solves many problems. Does it happen all the time or is it only with specific sessions? You will need to find out...Sessions can become corrupt and you may have to open a fresh session and import your tracks into it one at a time.
Being a Windows user, I know corrupt Windows files can cause problems with PT. Run chkdsk, sfc and dism to find out and repair system files. It's good to do this regularly.
Are you running large sessions with lots of VI's? PT sometimes has issues running lots of VI's. You may need to increase your RAM. SSD's are better than HDDs for sessions, audio and sample streaming.
Are there many plugins in your session? Low buffer settings can cause problems with CPU usage in large/busy sessions.
Happy troubleshooting! All the best...hope you find a solution.
MSI Pro Z790 Edge | i913900k @ 5.7GHz | 64GB DDR5 5600| 8TB NVMe | 3TB SATA SSD |10TB WD Black | Audient iD14 | PT 2022.12| Win 11 Pro | Tons of VIs and plugins
Old 08-06-2020, 04:20 AM
Or volume automation.
I'd also check the MIDI driving whatever vi is in use to see if there's any messages there that shouldn't be. OP doesn't say what vi he's using.
Old 08-06-2020, 05:01 AM
Cowboy Bob's Avatar
Cowboy Bob Cowboy Bob is online now
Did you play in the parts yourself or are they midi loops you got from someplace else?
I had a client send me a midi performance that she wanted included in a mix I was doing for her and had a very similar issue. The midi would start late and come and out.
What it wound up being was a CC message and a program change that caused it. I stripped out all cc and program change messages, only leaving the sustain pedal and it worked fine.
Take a look there, in the automation lanes of the instrument track.
@musicman691 Jack just saw your reply. Great minds and all.
"If the grass looks greener on the other side of the fence, well, it is likely due to the amount of manure being spread on that side of the fence." Cowboy Bob
Squaw Creek Road Studio
Bob
Pro Tools Ultimate (2024.3.1)| Pro Tools Carbon | Sibelius Ultimate (2024.3.1)
M2 Max Mac Studio w/64GB RAM | 1TB SSD | Mac OS 14.4.1| (Main Rig) |
3.6GHz 8-core 9th-generation Intel Core i9 processor iMac w/40GB RAM | 1TB SSD | macOS Ventura 13.3.1 |
Avid Eleven Rack ERXP | Focusrite Clarett 8Pre X |
Old 08-06-2020, 05:32 AM
I've fallen prone to that from some MIDI files I downloaded from the 'net. The other one I see is notes with zero length in the MIDI event list. Drives me batty.
Old 08-06-2020, 11:53 AM
Eric Lambert's Avatar
He's talking about random drop-outs, and that moving MIDI to a MIDI track fixes it, so that tells us a lot.
We ran into this issue quite a lot with prior versions of PT, to the point that I would never put MIDI on an Instrument track, but I haven't seen this issue at all over the past 6 months or so (I'm on PT 2020.3 with OS Mojave). What we would also see often was reopening a session that had been created at a previous time and the MIDI on an Instrument track was greyed-out and refused to play with that instrument. We had to copy MIDI to MIDI tracks, as you're doing. This was infuriating and it wasn't entirely rare. So our whole team of composers stopped using MIDI on Instrument tracks. I believe we've all returned back to it though.
So, a little more information about your configuration would help us a lot.
Old 08-06-2020, 12:00 PM
Did you open instrument view in the edit screen to check the MIDI routing on said instrument track? We all know that PT sometimes loses the routing.
Actually the op doesn't say anything about moving the MIDI to a MIDI track. He says he has to copy his instrumental tracks to a normal track and he doesn't say anything about MIDI. Never assume what someone means - that's dangerous. Besides what's a 'normal track' anyways?
Old 08-06-2020, 09:08 PM
He either copied the VI to an Audio or Aux track, or he moved MIDI to a MIDI track -- in any of these cases he'd have to move MIDI to a MIDI track. And most of this thread is making assumptions due to the fact that, like many threads here, the OP's question lacked details. Much of this forum is based on assumptions.
problem with multiple instrument tracks on ptle 7.4 catfishblues MIDI 1 02-28-2008 11:20 AM
Huge problem with Instrument tracks on PTLE 7.0 mantaray 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 01-27-2007 12:00 PM
CS8 midi instrument tracks and Xpand problem crizdee Pro Tools TDM Systems (Mac) 0 06-21-2006 04:28 AM
PTLE V.6 Midi/Aux Instrument tracks problem slambridis 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 6 02-01-2006 04:46 PM
PT7 - Instrument Tracks - Control Change Problem? Digitalkidd 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 12-02-2005 03:01 PM
