PT9 can't find Eleven Rack as playback engine!
Upgraded to pt9 today (11R worked flawlessly in PT8).
Cannot find Eleven rack under playback engine, only finds my duet and pro tools agreggate i/o, which I don't want to use as I want to monitor thru the Eleven rack. Any ideas? |
Re: PT9 can't find Eleven Rack as playback engine!
It hasn't done that to me for a while, but it did when I first upgraded to 9.
Quit protools, power off your 11 rack and on again then relaunch protools. Should be OK. What I found is that it always works OK if I power up my imac and then switch on the 11 rack as the very last thing before launching protools. You could also try re-installing the Eleven rack driver (I assume you have installed the updated 11 rack driver already?) Best of luck.
MojoBat Productions |
Thanks Bubblegum, about 10 minutes ago I downloaded the Eleven Rack driver from the Avid site and installed it, and it now shows up as a device again - success!
Eleven rack playback | evany | Eleven Rack | 3 | 07-12-2011 05:17 PM |
PT-HD9 vs. PT-HD9 using Eleven Rack's Playback Engine | acmost | Pro Tools 9 | 0 | 11-14-2010 08:23 AM |
Where to find Audio Drivers for Eleven Rack | 00011011 | Eleven Rack | 6 | 10-12-2010 08:57 PM |
LE 5.2.1 with AM III doesn't find Mbox in "Playback Engine". | Taki.M | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 04-04-2002 04:36 PM |
