Been looking for a way to arm an audio track in PT 8 by way of keyboard shortcut. I'm recording myself using a wireless keyboard from inside my booth, so I can't click on the record enable button (R) without stepping out of the booth. I know about F12 and 3 on the number pad but that won't help if the track isn't already armed. I need to know how to "arm" the track. Does anyone know the shortcut for this (if any) or have any suggestions... besides have someone track my session for me?
![]() Sorry if this has already been posted. Couldn't find any info. |
I am not aware of a shortcut. My solution is to have a mouse and monitor in the booth so I can actually run the entire session from there. I use a VGA splitter on my edit window screen(could easily be the mix window screen as I run dual LCD's). Of course that requires a cable(and I have a loom with VGA and PS2 connections). I bet there is some wireless VGA solution out there
Gigabyte X79/intel i7 3930K, 32GB RAM, Presonus Studio 1810C https://www.facebook.com/search/top/...0sound%20works I started in this business with nothing..........and I have most of it left ![]() BTW, my name is Dave, but most people call me.........................Dave |
Thanks albee1952, I was just hoping there could be a shortcut out there. It looks like the monitor in the room idea is the most do-able. Thanks for the quick response.
SHIFT+R
On the highlighted track(s) So u could always use 'P' OR ';' to tab to a certain track & then SHIFT 'R'
MYSPACE ON'EIM LAUTEN MICS & ME DA'TUBE ON'EIM 'IS TAMARA HOME' ![]() NO, SHE'S WITH HOBO KEY ' ![]() ('we' must start using pronouns) |
Why can't you leave the track armed for record? Record Arming the track and then using F12 or NKP3 will start recording and Spacebar will stop recording. If you have Insertion Follows Playback turned on - in Preferences or in Commands Focus Mode toggle it on and off with the N key - the cursor will be at the end of the recording and hitting F12 or NKP3 again won't record over the previous recording.
Or just go with Key's suggestion Actually. Cheers,
Take your projects to the next level with a non-union national read at a reasonable rate Demos: brucehayward dot com Source-Connect: brucehayward |
Maybe this is old hat but just found this:
http://www.m-audio.com/images/global...ts%20Guide.pdf Short cuts heaven and there IS a record enable hot key, so awesome ![]() |
Thanks for SHIFT R tip!
KEY!!!!
Only 11 months late! ![]() Cheers,
Weeds on'eim!!! In my case, more like 4yrs later!!! Hahaha
I don't think I've posted since 2011 ![]()
MYSPACE ON'EIM LAUTEN MICS & ME DA'TUBE ON'EIM 'IS TAMARA HOME' ![]() NO, SHE'S WITH HOBO KEY ' ![]() ('we' must start using pronouns) Last edited by Keybeeetsss; 08-13-2015 at 10:23 AM. Reason: Just looked up my last post |
Track Record Enable/Mute/Solo shortcut keys? | maufau | Pro Tools TDM Systems (Mac) | 2 | 07-06-2008 11:11 AM |
Shortcut for record enable track | west1977 | Tips & Tricks | 3 | 08-24-2006 07:18 AM |
Keyboard shortcut for audio track record arm? | smasyd | Pro Tools TDM Systems (Win) | 0 | 04-02-2006 07:57 PM |
record-enable track keyboard shortcut | redcootie | Pro Tools TDM Systems (Mac) | 1 | 12-22-2005 12:02 AM |
Put in Record Enabled a TRACK (keyboard Shortcut) | Montxo | Tips & Tricks | 3 | 05-06-2001 10:22 AM |
