Old 08-06-2007, 03:57 PM
Maya Maya is offline
Default UNINSTALLED AND INSTALLED PRO TOOLS 7.0 AND IT WON\'T LAUNCH
HI,
I recently upgraded pro tools to 7.3 but was having some problems. I decided to go back to 7.0 so I uninstalled pro tools and re installed it. Now I can't open it. It says something like "digidesign hardware is in use by another application (-1133)".
What am I doing wrong?
I have an iBook G4.
Version 10.4.9
Processor 1.33 GHz
Memory 768 MB
And I work with MBox 2
I never had a problem before. Can anyone help??
Maya
Old 08-06-2007, 04:50 PM
DigiTechSupt's Avatar
Default Re: UNINSTALLED AND INSTALLED PRO TOOLS 7.0 AND IT WON\'T LAUNCH
How did you uninstall Pro Tools, exactly?
Avid Audio Tech Support
Support FAQ
Old 08-06-2007, 05:03 PM
I inserted the Pro Tools Install CD, clicked on Uninstall. It said that everything was uninstalled. Then I clicked Install again and it finishe installing fine. When I clicked on the icon to launch it, it looked like it was going to launch but then it stopped and that's when it said that thing about digidesign, etc.
Old 08-06-2007, 06:15 PM
webStalkers webStalkers is offline
im having the same problem right now. Ive had 7.1 on my new mac for about a week now and all of a sudden it wont run. I deleted it and reinstalled, rebooted and still nothing.
Old 08-07-2007, 10:30 AM
Did you do a 'clean' or 'safe' uninstall? You should be using 'clean' in this case...
Support FAQ
Old 08-07-2007, 10:31 AM
Which model mac? How did you uninstall? What do you mean by 'and still nothing'? Does it bounce in the dock? Unexpectedly quit?
You may want to read the Help us help you thread as well.
Support FAQ
Old 08-07-2007, 08:28 PM
tonicjeff tonicjeff is offline
Same problem here.. PT LE 7.3 Digi 003 mac Pro
Click icon and get bounce in dock and no app running.. Did "clean" uninstall and then reinstall from disc.. still same problem.. did a repair permissions.. all basic troubleshooting.. Digi: Any help? thanks
[/QUOTE]
Intel Nehalem 8 Core 2.26 w/10 gigs of Ram
4 internal sata drives (1 terabyte)
Magma Pci to PCIe 6 slot chassis
PT 8cs3
HD 2 Accel
1 Process Card
UAD quad
PT 8.0.1 cs 1
OSX 10.5.8
Ctrl 24
Old 08-08-2007, 10:20 AM
[/QUOTE]
Mac OS 10.4.9 and 10.4.10 information and troubleshooting
Most likely you need to install the proper combo update and run the PACE prebind script...
Support FAQ
Old 08-08-2007, 10:30 AM
thank you.. done and it worked...
PT 8cs3
HD 2 Accel
1 Process Card
UAD quad
PT 8.0.1 cs 1
OSX 10.5.8
Ctrl 24
Old 08-08-2007, 10:31 AM
mattshort mattshort is offline
I'm having the same problem. Protools was quitting on me alot. I went on digi's website and installed the latest update. It didn't really fix anything, I was still experiencing the unexpected quits. Then, today, Protools won't even launch. I click on it in the dock and the startup window appears but, there's nothing happening in the progress bar & I get the dreaded spinning beachball. I go to force quit and it shows PT not responding. I ran the prebind app and it said no repairs were necessary.
I'm on a G4 dual 1.42, 2GBram, Mbox, OSX.4.10
Pro Tools Won't Launch - IE8 not installed Jody Stevens 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 13 08-28-2012 05:27 PM
Pro Tools 9 Won't Launch w/ 002 Drivers installed. xbuzzlightyearz macOS 1 10-20-2011 12:26 PM
uninstalled PT 8 - error comes up - installed pt9 jayprotools macOS 1 02-11-2011 10:29 AM
installed pro tools 8- will not launch? fenderusa2003 Pro Tools M-Powered (Win) 1 07-30-2009 07:21 AM
Pro Tools will not launch b/c I installed Reason 4.0 Barrington 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 09-03-2008 01:10 PM
