how do U merge sessions w/different frame rates???
hey guys,
I've got one session that was recorded at 44.1 with a frame rate of 25 (logic audio default) and another session that is 48k with a frame rate of 30 at another studio. I'm not to worried about the sample rate conversion but not sure what to do about the frame rate. Ideally I need to get the 48k session w/30 frame rate into the 44.1 session with 25 frame rate. At this point both sessions are in pt. Any ideas??? thanks, ej |
Re: how do U merge sessions w/different frame rates???
Are these sessions locked to video? If they are just music sessions, then just import one into the other at the sample rate you want to work in and change the frame rate. (It would probably sound better converting the 48k session down to 44.1).
If you are locked to video, then you have to deal with the NTSC->PAL conversion, of which there is another lengthy thread currently in the Post & Surround forum you may want to look at.
Save early and often! (or once a day whether you need to or not...) |
You are talking about strictly audio sessions, right? If so, do not worry about the frame rates. As long as you resolve the differences with the sample rates, the frame rates will not matter as long as you have a sync point on both sessions. Remember that in strictly digital audio the “speed” the audio is running is the sample rate. The frame rate is simply a labeling system. (Okay, when resolving two machines together it’s not that simple, but we’re not talking about that here...) When you import tracks from a session with a different frame rate, but same sample rate, you can simply drag the imported audio into sync.
If this is supposed to sync to video, well, ignore everything I just said!
-Charles D. Ballard, M.P.S.E. "I bent my wookie" |
Hehe... Sorry to just repeat... I tought of re-freshing the page before I answered (I opened it and got distracted on another task)... Guess I should have...
thanks guys!!!
i'll give your suggestions a shot. I really appreciate your input. fortunately for me this will not be synced to video. thanks again, ej |
hey, tomorrow I can help you do this if you get stuck.
Later, Kurt [email protected] Intel duel Quad core PT 8.0cs3 HD4 D Command / D control |
thanks kurt!
i feel like the luckiest non engineer pt user on earth. to be in L.A. and to have access the guys like Kurt, Tony Sheppard, Bill Malina, & Rail not to mention all of you L.A. guys who posted on this thread...Thanks to you all...what more could a producer ask for. ej |
Multiple frame rates | idris | Post - Surround - Video | 1 | 02-12-2014 01:44 AM |
DA88 frame rates | Katherine | Pro Tools TDM Systems (Mac) | 6 | 12-06-2005 07:33 AM |
NTSC, PAL and PT frame rates | Inaam | Post - Surround - Video | 2 | 11-25-2004 08:55 AM |
frame rates | jaysun | Pro Tools TDM Systems (Mac) | 3 | 03-11-2002 02:38 PM |
Postconform with different frame rates. | rpalagy | Pro Tools TDM Systems (Mac) | 1 | 06-13-2000 10:08 AM |
