Old 09-10-2020, 12:49 AM
Burmansound Burmansound is offline
Default Pro Tools could not set sample rate to specified value
Hi everyone. After installing v2019.6 for a friend's session, and then going back my v12.5, I get this error every morning when I first open a 48K session - "Could not complete your request because Pro Tools could not set sample rate to specified value".
I dismiss the error, and then open the session again, and it works fine.
I've never seen this error before. What could be causing it? I guess I'll try trashing the prefs, and if that doesn't work, reinstalling.
Cheers,
Ellis
Old 09-10-2020, 12:54 AM
Default Clock Source: See Control Panel
Hi everyone. After installing v2019.6 for a friend's session, and then going back my v12.5, my system no longer sees my Sync HD. I also notice this odd behavior in the session setup window: The clock source is greyed out and says "See Control Panel". Which control panel? Where? My playback engine is HD native. I don't see any clock settings in the Mac sound setup. Where is this mysterious control panel it's talking about?
I think this might be related to the "Could not complete your request because Pro Tools could not set sample rate to specified value" error I've been getting every morning when I first open a session.
Thanks,
Ellis
Pro Tools Changes the Sample Rate Lucas Melo Pro Tools | Intro Discussion 7 09-24-2019 09:29 AM
Pro Tools First could not set sample rate to specified value [email protected] Getting Started 5 09-06-2019 11:22 AM
Let Pro Tools set system sample rate philonguitar Tips & Tricks 4 04-02-2015 02:31 PM
Pro Tools could not set sample rate to specified value Prabha Pro Tools 11 5 09-08-2014 10:59 AM
Pro Tools could not set sample rate to specified value SixStringRockteer Pro Tools 9 4 06-29-2013 05:24 PM
