Old 07-15-2018, 05:24 PM
simmosyd simmosyd is offline
Default Waveform not displaying
So I am having issues suddenly with any new Pro Tools session that I creating when importing audio files where Pro Tools won't visually show the waveform.
I have 'waveform' selected on the left of the track and not 'blocks' or anything like that.
The strange thing is some tracks show the waveform and others don't until I zoom in a couple of clicks and suddenly the waveform appears.
Sounds like a bug with Pro Tools?
Pro Tools version: 2018.4.0
OS: Windows 10
Old 07-15-2018, 06:05 PM
Bob L's Avatar
Bob L Bob L is offline
Default Re: Waveform not displaying
Do the missing waveforms appear when you Recalculate Waveforms?
Bob
Without a song
The day would never end
Old 07-15-2018, 07:03 PM
Thanks for the reply.
I have tried this and it doesn't help, unfortunately.
Old 07-15-2018, 08:26 PM
jjnssn jjnssn is offline
What if you delete the wavecache files? Try making the height of tracks larger or smaller? Just guessing.
Old 07-15-2018, 10:59 PM
Stephen Bond's Avatar
+1
Mac mini M1 2020 16Gb Memory- 256Gb Storage, Monterey, Pro Tools 2022.9, Focusrite Scarlett 2i2
https://www.waves.com/r/djgsi6
Old 07-16-2018, 12:55 AM
I've just deleted the wavecache files now and that has made it even worse, now more tracks aren't showing the visual waveform, it is as though I have it in 'blocks' but I don't.
Yet the audio exists (is audible) :/
Old 07-16-2018, 01:30 AM
BScout BScout is offline
If you've deleted the cache and reopen the session, it takes time for the waveforms to be redrawn. Do you see the spinning circle near the time counter (that indicates Pro Tools is working)? Or go to Window>task manager and see if Pro Tools is working.
Old 07-16-2018, 04:45 PM
The red circle isn't spinning near the time counter.
There is a task manager box that pops up in Pro Tools however with..
Name: Calculating Waveform Overviews.
Status: Assertion in "E:\Code\222370\ProTools\NewFileLibs\Ff\Audio\Elas tic\FF_PacketStreamSet.cpp", line 419.(Use the Copy button to copy this message to the clipboard.)
Old 07-16-2018, 04:51 PM
If it's red instead of green while working/spinning, then you have an error.
And there's your error. Looks like you have an elastic audio track/clip that is preventing the rest of the waveforms from calculating. Pretty much halting the process. You'll need to track down the bad audio in the session that is causing this.
As a troubleshooting step that I think will work, cancel the task with the error in task manager. Then highlight in the clip bin small groups of clips at a time to "recalculate waveforms" until you hit whatever is creating problems (keep the task manager open by the side to see it complete making waveforms or if it gets stalled.) That should narrow down the problem while also building the rest of the waveforms for the good files.
Old 07-16-2018, 08:02 PM
Thanks for the help with...
"As a troubleshooting step that I think will work, cancel the task with the error in task manager. Then highlight in the clip bin small groups of clips at a time to "recalculate waveforms" until you hit whatever is creating problems"
I have done this and it has been "Calculating Waveform Overviews" for the last couple of hours, will see if it eventually fixes it.
PT 8 - No displaying waveform properly bhughes Windows 1 04-02-2015 11:03 AM
Displaying SPL value Vedat ICON & C|24 3 02-20-2010 12:50 AM
Calculate waveform - where are waveform views stored? levelaudio 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 02-11-2010 07:18 AM
waveform displaying during recording STUDIO A 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 01-03-2005 08:48 AM
