001 and Motor Mix
I have a little problem. I keep loosing communication with my motor mix. I know my set-up is not the problem because it works 80 percent of the time. Just that 20% it looses communication. When I get into OMS and test the studio it says I am sending 2 or more midi events which may cause confusion and I should get the controller out of dual mode. And I don't know how to do that. No instructions in the manual either. Any suggestions would be appreciated.
Re: 001 and Motor Mix
same problem with me - anyone - please?
cheers spong |
I would have to say I don't have that problem anymore. Turns out I had a older motor mix unit and I had to update the firmware to 1.08. A good thing to check is to check your firmware, next see if the motor mix is in pro tools mode, and then go to the midi column in your pro tools session and then into inputs and see if motor mix is checked. Good luck! All I have to say mine works really great now. Wish I had 2 of them. [img]images/icons/grin.gif[/img]
Motor Mix | musicalone | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 04-21-2004 05:29 PM |
motor mix in HD | Ploch Klaus | Pro Tools TDM Systems (Mac) | 2 | 09-17-2002 12:59 AM |
Motor Mix | fcpercinotti | ProControl, Control|24, Command|8 | 1 | 05-02-2002 08:02 AM |
Motor Mix | fcpercinotti | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 03-16-2002 11:01 PM |
I'm using the O1V as a motor mix but... | Dead River Studio | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 08-18-2001 01:31 PM |
