Urgent help - digi192
Just setting up a 192 I ve just bought with an 8 out expansion card (analogue) - so I have 16 analogue outs via dsub to jack - PROBLEM
1-8 outs are signifcantly quieter than 9-10 I've done obvious and swapped leads and still same problem. When I go into hardware in protools there is no +4 OR -10 option just an a OR b next to each anaolgue output ....... HELP I'm thinking it's a simple case of outputs 9-16 set at different level to 1-8 but I just can't locate how to change it -only other option is my analogue 1-8 card is not working ...... Please - someone help ... Karl |
Re: Urgent help - digi192
are there trim pots on the back of the new card?
Ill check - there s def 16 small holes under db25 connector - to be fair it's 1-8 that sound low ....
Thanks kj |
Under the analogue output on dsub there is 16 holes with small screws - start from 1a,1b so on ang goes to 8b - what are these??
kj |
Calibration screws. You have two different calibration sets, A and B, which you can select from the PT hardware setup.
Help - lol - what does this mean/do?? - and can you tell me what might be matter with my 1-8 level output been low?? - anything to do with this??
ideas? cheers kj |
Well checked my desk and swapped channels and the problem lies in output coming from analogue 1-8 - massive difference in level to outputs 1-9 ....
I can't see anything in pro tools to change the output of 1-8 - is there?? - or is it what i'm starting to think a faulty analogue out card ?? kj |
Can anyone help - I'm really stuck on this - moved from a 96 i/o to a 192 and all I have is problems - first price of dsubs and now outputs 1-8 really low compared to 9-16 ..... Anyone had this problem before ?
Cheers Karl |
I bought the 192 used from a digi dealer in London - they have nt sent me a manual - is it definately a calibration problem - would/can outputs 1-8 be a different level to 9-16 with this??
Any helpofhowto do woud be great! Cheers kj |
Digi192 or aurora 16 ? (+ UA2192) | kikidi | Pro Tools TDM Systems (Mac) | 0 | 08-02-2010 10:07 AM |
apogee adda16 and digi192? | raga2000 | Pro Tools TDM Systems (Win) | 0 | 06-14-2010 12:31 PM |
Rosetta 800 - digi192 cable question | tpstudio | Pro Tools TDM Systems (Mac) | 5 | 04-03-2010 10:09 AM |
DIGI192 converter with PTM/LE low budget on PC only | soundmaster | Pro Tools M-Powered (Win) | 0 | 03-23-2008 07:28 AM |
Digi192, Clocking and ADC | Riad | Pro Tools TDM Systems (Win) | 5 | 05-30-2005 06:58 AM |
