Old 01-11-2009, 12:25 PM
stereodesign stereodesign is offline
Default PT 8 stopped working
I upgraded to PT 8 last week, everything went smoothly.
I used it on a session yesterday, again everything went smoothly.
Today I try to run PT and get the following error
"The application failed to initialize properly (0x80000003). Click on OK to terminate the application."
So I remove PT8 re-install, same problem.
I try removing PT 8 and re-installing PT7.4, same error.
A quick Google revealed someone who had this error in PT 8 LE and the replies were saying the only way to cure it was to re-install Windows, a somewhat drastic solution!
What has happened? Anyone else had this problem or know of a solution?
My PT rig just stopped working.. JCDC Pro Tools HDX & HD Native Systems (Mac) 4 01-01-2013 06:02 AM
my 192 just stopped working what do i do!?!?!? carl_laruso Pro Tools TDM Systems (Mac) 4 09-02-2008 03:55 AM
002 and why it just stopped working? Susie Cue 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 07-13-2008 07:44 PM
Just Stopped Working macr0w ProControl, Control|24, Command|8 0 12-11-2007 05:39 PM
HELP Mix|24 v6.4.1 just stopped working lennieh Pro Tools TDM Systems (Win) 5 10-19-2006 05:26 PM
