Help managing audio files
Hi, this is probably a very simply question, but it has me stumped at the moment.
How do get pro-tools to save audio files at a specific location on a disk? I have set up a Session Template, which I want to use in order to save me having to create a new session for every song I want record. However once I have loaded up my template session, I want to make sure that all the audio files are stored in a new folder for each song. How do I direct Pro-Tools to a different folder other than the default "audio files" folder that was created with the template? Any help welcome. Ian |
Re: Help managing audio files
Under the setup menu, you should find the disk allocation menu. option click on the top track and select choose folder. (by holding down option, it allocates all the tracks to the same destination, instead of having to do the allocation to every single track. Also are you creating you template as a stationary pad? This process works very well for templates, as you don't have to save as everytine you open up that session, it will prompt you to either create a new session, or edit stationary pad.
Hope this helps. Dan Cheung Solid Sound Studios/Legacy Entertainment Los Angeles CA
Dan Cheung 2.5 Ghz Quad G5 Power PC 4 gigs of RAM OS 10.5.x Leopard Protools LE 7.4 Mbox II |
Thanks, I give that a go!
Managing audio/ workflow... | montreal | macOS | 17 | 10-21-2013 08:30 PM |
usaved PT session saving unsaved audio files to audio files folder | mermermer | Pro Tools HDX & HD Native Systems (Mac) | 1 | 07-18-2012 11:50 AM |
Managing files | tombliss | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 09-07-2008 03:52 AM |
Managing session files | Gothboy | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 09-21-2007 06:06 AM |
Managing audio files. HELP!!! | pfd4 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 11-15-2002 11:59 AM |
