iLok not seen - client not happy!!
I have sveral iLoks going, as always - one for PT, one for plugs etc. - and my client is trying to use his as well, but PT is not seeing it. Of course it has all the plugs we need for his mixes......
help?
Composer/Sound Designer/Protools 2024.3 Ultimate, MTRXII-TB3, DADMAN MOM, Cisco SG350-10MP EthernetHUB, KLANG:quelle 4 Channel Dante™Headphone Amp, DVS,MADI, Mac Studio Ultra,128 RAM/4TB SSD, Ventura 13.6.6, DP 11.3.1, Logic Pro X 10.8.1 DOLBY ATMOS Facility/MPSE Motion Picture Sound Editors Avid Certified Professional ProTools/Dolby ATMOS |
Re: iLok not seen - client not happy!!
obvious question, but have you installed the plugins? Have you logged into ilok.com to see if the ilok is connected ok and the auth's are all there! The auth's in this ilok are compatible with the plugin versions you have installed on your system!! Chris
Greg
Also if any are Massive Pack authorizations, those are specific to those versions. Did he bring his versions from his system? And not sure if this was mentioned, are they current to your version of PT? hope it gets worked out. |
We will take a look tomorrow..Thursday.. We had a day off today.. I know there are plugins install and no Massive stuff that I know of.. We are only seeing Smack which is unusual and no others like Pultec, SoundToys Native etc. of which he is using Echo Boy for all of his reverbs.. I'll pass this along to him. G
If the suggestions given above don't work, you might want to try a different USB hub. The one you're using might have problems, or be sub-standard.
Lee Blaske |
CAZADOR RECORDING PT10.3.10/HD6/192w16in/MTN.LION OS 10.8.5 / Westmere MacPro 8 Core W/20gRAM MAGMA-PE6R4/TDM&RTAS/WAVES Platinum/UA/Eventide Plugs/I usually record at 88.2 With GOD as my partner. . . I need to make my plans LARGER. |
D-Link USB hubs are the way to go imho.
ilok issues - ProTools 9 crossgrade LE (Please install the iLok Client Software) | pauledwards | Windows | 3 | 09-10-2013 04:02 PM |
iLok client software | crazehiphop | Pro Tools 10 | 19 | 08-25-2012 10:16 AM |
iLok Client Software | schoei1 | Windows | 2 | 05-04-2012 12:05 PM |
iLok Client Install Problems | BenjaminCostello | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 05-29-2006 08:59 PM |
iLok Client Crud | tha k man | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 07-04-2005 10:33 PM |
