Old 01-29-2018, 10:18 AM
aklru aklru is offline
Default PT 2018.1 crashes on boot, 12.8.3 worked perfectly [SOLVED]
So I wanted to check out the new features, and installed 2018.1.0.
I can't get past this error and consequent crash:
assertion in "e:\ code\ 222370\ ProTools\ App\ Document\ UProToolsWindowPresetMgr.cpp", line 250.
which comes up while Initializing Databases.
It also says (Use the Copy button to copy this message...) but the usual Copy button is not there.
I have tried:
- quit any irrelevant services running
- trashing prefs and restart - also between every other step
- uninstall+reinstall audio driver (Scarlett 2i2 1st gen)
- uninstall+reinstall Pro Tools
- moving all plugins to unused
- refresh iLok, remove and insert it physically
- updated Waves plugins
- tried with and without MIDI keyboards
Windows 10 Pro, 64bit.
Creator's Fail Update came in the other day, but that didn't kill 12.8.3.
I have followed all the optimization advice, and deactivated a lot of stuff like Superfetch etc in Windows.
Onboard soundchip is deactivated in BIOS, so are C-states.
Yes, the rig is overclocked, but has been running 24/7 stable since 2011.
Ableton Live works as usual.
Did anybody else have this problem?
I can't find anything on Google or here on the duc.
The error message:
SiSoftware Sandra
ID
Host Name : DESKTOP-6VHM20A
Workgroup : WORKGROUP
Computer
Model : GigaByte GA-990FXA-UD3
Chassis : GigaByte Desktop
Mainboard : GigaByte GA-990FXA-UD3
BIOS : Award (OEM) FFe 11/08/2013
Total Memory : 16GB DIMM DDR3
Processors
Processor : AMD FX(tm)-8120 Eight-Core Processor (4C 8T 4.18GHz/4.64GHz, 2.55GHz IMC, 4x 2MB L2, 8MB L3)
Socket/Slot : AM2r2/AM3
Chipset
Memory Controller : AMD F15 (Orochi) CPU HT Hub 2x 1GHz (2.09GHz), 2x 8GB DIMM DDR3 1.86GHz 128-bit
Memory Module(s)
Memory Module : Kingston KHX1866C9D34GX 4GB DIMM DDR3 PC3-14900U DDR3-1866 (9-9-9-25 4-34-10-5)
Video System
Monitor/Panel : BNQ BenQG2110W
(1680x1050, 22.0")
Video Adapter : NVIDIA GeForce GTX 1080 (2560SP SM5.2 1.63GHz/2GHz, 2.9GB 10GHz, PCIe 2.0 x16)
Graphics Processor
D3D 11 : NVIDIA GeForce GTX 1080 (2560SP 1.63GHz/2GHz, 8GB 10GHz)
OpenGL : GeForce GTX 1080/PCIe/SSE2 (8GB)
Storage Devices
Corsair Force 3 SSD (120GB, SATA600, SSD) : 112GB (F:)
Corsair Force 3 SSD (120GB, SATA600, SSD) : 112GB (C:)
WDC WD7500AAKS-00RBA0 (750.2GB, SATA300, 3.5", 7200rpm, 16MB Cache) : 699GB (D:)
Logical Storage Devices
soundprt (F:) : 112GB (NTFS, 4kB) @ Corsair Force 3 SSD (120GB, SATA600, SSD)
Reservert av systemet : 500MB (NTFS, 4kB) @ Corsair Force 3 SSD (120GB, SATA600, SSD)
DATADISK (D:) : 699GB (NTFS, 4kB) @ WDC WD7500AAKS-00RBA0 (750.2GB, SATA300, 3.5", 7200rpm, 16MB Cache)
Hard Disk (C:) : 111GB (NTFS, 4kB) @ Corsair Force 3 SSD (120GB, SATA600, SSD)
Peripherals
LPC Hub Controller #1 : AMD IXP SB600/700/800 SMBUS Controller
LPC Hub Controller #2 : AMD SB700/800 LPC host controller
LPC Legacy Controller #1 : ITE IT8720F
Audio Device : MSI GP104 High Definition Audio Controller
Disk Controller : Gigabyte SB700/800 SATA Controller [AHCI mode]
USB Controller #1 : Gigabyte SB700/800 USB OHCI0 Controller
USB Controller #2 : Gigabyte SB700/800 USB EHCI Controller
USB Controller #3 : Gigabyte SB700/800 USB OHCI0 Controller
USB Controller #4 : Gigabyte SB700/800 USB EHCI Controller
USB Controller #5 : Gigabyte SB700/800 USB OHCI2 Controller
USB Controller #6 : Gigabyte SB700/800 USB OHCI0 Controller
USB Controller #7 : Gigabyte SB700/800 USB EHCI Controller
USB Controller #8 : Gigabyte Etron USB 3.0 Extensible Host Controller
SMBus/i2c Controller #1 : ATI SB800 SMBus
Printers and Faxes
Printer : Microsoft Print To PDF (600x600, Colour)
Network Services
Network Adapter : Realtek PCIe GBE Family Controller (Ethernet)
Wireless Adapter : Qualcomm Atheros AR938x Wireless Network Adapter (802.11n (HT), AES-CCMP, 450Mbps)
Operating System
Windows System : Microsoft Windows 10 Professional 10.0.16299
Platform Compliance : x64
Performance Enhancing Tips
Warning 2513 : TPM not detected. Some security features are unavailable.
Tip 2 : Double-click tip or press Enter while a tip is selected for more information about the tip.
Old 01-29-2018, 10:44 AM
Default Re: PT 2018.1 crashes on boot, 12.8.3 worked perfectly
I use Trasher btw, and it can't find any of the folders or databases ever since I installed 2018.
System Details
Pro Tools Perpetual
Scarlett 2i2
Windows 10 Pro x64
AMD FX-8120 @ 4.16 GHz, 8 Core
16 GB RAM, 1865 MHz
MSI GTX 1080 Aero
Old 01-29-2018, 01:21 PM
The Weed's Avatar
The Weed The Weed is offline
The drive says "e:\...." for the error. PT is installed on the C: drive, yes?
non-union national read at a reasonable rate
Demos: brucehayward dot com
Source-Connect: brucehayward
Old 01-29-2018, 01:40 PM
BScout BScout is offline
That's just from the compiler code messaging system (the developer had it on an e drive with the codebase.) Not relevant for the compiled program.
Can you get to workspaces? If you can, highlight the track presets, right click and select updated indexes. In fact, if databases are missing, go through all the locations (catalog and volumes) and have them update or rebuild by right clicking and selecting the appropriate option.
Old 01-29-2018, 02:24 PM
Thank you for answering, guys!
Ironically, I just now found a solution.
Made another user account (administrator) as per Avid's Troubleshooting guide's last resort.
Logged in there and started PT, which worked!
Then I found a more populated "Pro Tools" folder in the new user's "Document" folder, so I just copied that over to my regular user account.
Now PT starts like it should!
Not sure how this could have gone wrong, but at least for now the program starts. We'll see about working with sessions and 3rd pty plugs etc...
System Details
Pro Tools Perpetual
Scarlett 2i2
Windows 10 Pro x64
16 GB RAM, 1865 MHz
MSI GTX 1080 Aero
Old 01-30-2018, 02:26 PM
A little update on this issue:
I caused this all by myself.
This was some time ago, so I didn't think of it when PT didn't want to start.
Wanting to gain more control over cpu usage and background tasks, and get rid of bloat/spyware in Win10, I set about deactivating services etc.
Turns out that because I took ownership of several parts of registry and the C: drive, to get rid of the crap, TrustedInstaller couldn't do it's job anymore.
I'm still working out some kinks with other stuff.
What I learnt these last days: Don't take ownership to mess with your system, grant yourself permissions if you have to.
Or more generally, the lesson that never seems to sink in:
TL;DR: Don't mess with stuff on your workhorse if you're not 100% sure it's safe!
xD
System Details
Pro Tools Perpetual
Scarlett 2i2
Windows 10 Pro x64
16 GB RAM, 1865 MHz
MSI GTX 1080 Aero
2018.1 Runs perfectly Shatzer Pro Tools 2018 57 02-03-2018 08:22 AM
Anyone else missing trim plugin after 2018 upgrade? [solved] ratava911 Pro Tools 2018 4 01-30-2018 06:08 AM
PT 12.7 on MacBook Pro w. Sierra - worked fine now crashes everytime I try to launch JRup Pro Tools 12 2 01-08-2017 04:09 PM
Pro tools 10 hd worked perfectly. Suddenly freezing and SUPER slow Sust Pro Tools 10 7 12-22-2015 04:26 PM
Problem solved: OS X / 9.2.2 boot drive switching ragbor Pro Tools TDM Systems (Mac) 4 08-26-2002 12:22 AM
